Car not warming properly
Old Dec 8, 2013 | 01:42 PM
Originally Posted by dbaldwin
No CEL, just temp gauge not showing car warming up past 150 and heat blowing warm at best.
OK. Based on that, sounds like a T-stat hanging open or air in the system (but air pockets tend to cause the temp sensor to read high).
I would definitely change the T-stat. If you can do it, a coolant flush before hand and JC mentioned the coolant elbows, if they have not been changed, do those since you have to re-fill the system anyways.
Old Dec 9, 2013 | 12:31 PM
dbaldwin's Avatar
Just popped CEL, not very warm today so im going the change the tstat out with as little coolant loss as possible and not flush the system.
Old Dec 10, 2013 | 03:57 PM
Madmillz09's Avatar
Just had basically the same issue with mine about 2 weeks ago and after swapping the tstat its been running fine again.
Old Dec 12, 2013 | 02:43 PM
ndaguanno's Avatar
Even with it being 10 degrees here my gauge still gets to the line above a quarter, thermostat opens a few lines before half. I'm sure you have it figured out just wanted to comment anyway.
Old Dec 12, 2013 | 03:13 PM
dbaldwin's Avatar
Yeah replacing the thermostat did the trick.
tpulliam79
Oct 27, 2011 05:53 AM
FakeAccident06
Feb 19, 2010 03:55 PM
cmeadows06
Jun 18, 2009 02:44 PM
XM_JDM
Feb 19, 2009 12:50 PM
golfstud2k4
Jan 8, 2007 04:10 AM
