Fuel Guage is not working properly on my 01 SS
Old Jan 7, 2007 | 01:13 PM
golfstud2k4's Avatar
Default Fuel Guage is not working properly on my 01 SS
I have a 2001 monte carlo ss and the fuel guage will bounce all over the place. The only way I can tell how much gas I have is by using the digital display and look how many gallons I have used. Any ideas why the guage will move around as I drive down the road or park on a change in grade???
Old Jan 7, 2007 | 01:16 PM
wiz kidd's Avatar
Default RE: Fuel Guage is not working properly on my 01 SS
possibly it could be a fuel tank sending unit, which most likely (when i get to work double check) come with the fuel pump as well, which means it could be a biiiiiiiiiig dollar fix.
thats most likely a worst case senario, but it could be that
Old Jan 7, 2007 | 02:02 PM
mickey's Avatar
easy way to find out id go to a bone yard and find a guage pod and replace yours for a few miles to find out if it stops.
but i owuld check the groud etc... first..
or call a dealer if you get in tight with one of the guys behand the contrer they can sometimes tell you what it might be also.
Old Jan 7, 2007 | 09:05 PM
01BlkSS's Avatar
Probably the sensor on the fuel pump in the tank. Had the same problem on a buick century. Just went to the junk yard and got a used fuel pump assembly for $40 and it works like a charm now!
Old Jan 8, 2007 | 04:10 AM
mickey's Avatar
sitting here thinking of this. if yoru speedo is off also i would defently check in to a diffrent pod.
thinking of this it is a whole unit in there it is not seperate guages. So with that said it could be that hte bread bord is goign bad and it is showing this in more then one guage. So the speedo is off and the gas needel is bouncing.
blackmonte781
Sep 14, 2011 08:46 PM
pinky71103
Oct 6, 2010 08:02 PM
neil0215
May 27, 2010 09:43 PM
FakeAccident06
Feb 19, 2010 03:55 PM
cmeadows06
Jun 18, 2009 02:44 PM
