Car misbehaving after Trans Flush
Old Jun 4, 2014 | 08:06 AM
God_Bot's Avatar
Mine started slipping from a stop a month or two ago. Had it diagnosed as a failing pressure control solenoid. That's a pretty common issue with this transmissions. Basically pressure wouldn't be high enough for first gear to fully engage so it'd start in second and then slam into first. Dropping the gear selector down into 1 results in higher line pressure and the car would leave a stop just fine.
Local shop quoted me around $500-$600 to replace all the electronics in the transmission (my clutches are fine still). I ended up paying on of the mechanics where I work to do it on the side and now the car is shifting like it should.
Old Jun 4, 2014 | 09:28 AM
Question > 2 Flush or not 2 Flush > That is the Quesion ?<
Grizzly, please keep us updated on your trans prob's & what you are going to do ? > Thanks
Below are some Links to check out
Transmission Flush Good or Bad?
I constantly hear consumer, customers and technicians debate as to whether transmission flush procedures can be harmful to a vehicle and is a transmission flush good or bad for your automobile. While many mechanics and experts agree that having a clean transmission will extend the life of a transmission, it is thought by some that the flushing procedure may not be the best way to achieve a clean transmission. One common thought is that the process, which forces liquid back into the transmission in the opposite way of the normal fluid flow, could potentially damage components or block tight passageways. When fluid is forcefully pushed back into the transmission, chunks of debris can be dislodged and possibly block narrow channels or one-way valves. When new fluid is put back in, these blockages can inhibit the normal flow of fluid through the transmission causing lubrication issues. Nonetheless, many car manufacturers and dealerships contend that these procedures are not harmful at all and help revitalize auto transmissions. MDH Motors does not use a reverse flush machine and over the thirteen years of being in the automotive repair industry I still yet to have seen a machine that flushes the fluid in reverse. Most machines just pump the new fluid in through the transmsiion cooler lines while containing the old fluid in a separate tank. The best transmission flush operation procedure is to:
  1. Perform the transmission flush
  2. Remove the pan and change the transmission filterDoing the flush in this order while help prevent the possibility of contaminates going through your transmission and potentially causing a problem by, let’s say hanging up a valve in the valve body.
">Do You Really Need to Change the Transmission Fluid ...
blogs.cars.com/.../do-you-really-need-to-change-the-transmissi...
Cars.com
Jul 2, 2013 - If you have never changed the transmission fluid in your vehicle andhave more than 100,000 ..... I shouldn't have to have a flush yet should I?
">Transmission Flush, When and when not to flush ...
mdhmotors.com/transmission-flush-when-and-when-not-to-flush-transmi...
by martin hand
A transmission flush procedure is generally performed using equipment that either runs ... If you are not sure what your vehicle requires, you can sometimes find ...
">Transmission Flush? - Car Talk
community.cartalk.com/discussion/2134883/transmission-flush
The dealer said I needed a transmission flush. I took it to ... The short story is that you should go ahead and have your pan dropped & filter replaced. This is not a ...
">5 Signs that Your Car Needs a Transmission Flush ...
www.carsdirect.com/car.../5-most-common-signs-that-your-car-needs-a-t...
In most cases, getting a transmission flush every 30,000 miles, or every two years or so is sufficient. However, there may be times when you need to get a ...
What is a Transmission Flush? | Process and Advice
www.transmissionrepaircostguide.com/what-is-a-transmission-flush/
However, if you feel there are certain problems with your vehicle such as odd .... It willtell you whether you to get a flush or change and how often to have it done ...
">Should I Have My Transmission Flushed - AGCO ...
www.agcoauto.com/content/news/p2_articleid/238
Automatic transmissions benefit from proper service. Unfortunately, many places push a highly profitable up-sell instead. The transmission flush does the vehicle ...
BeachBumMike
Dec 11, 2013 03:45 AM
jonapp
Jan 17, 2013 10:58 AM
iMSeRiOuS
13
Apr 5, 2010 01:07 PM
ashleymc34
30
Nov 1, 2009 10:03 PM
montejass
Oct 18, 2006 08:52 AM
