Can i add a supercharger to my 3.4 l monte
It's not worth your time really, not a lot of people are just in the market for the blower only, even if they were- adding shipping will push it up a lot too. If you were to get the full 'top swap' (heads, lim, rails, injectors, tb, blower, balancer, idlers, etc). You could sell that to an NA 3800 guy that is looking to top swap their car.
As far as putting it on your 3400, you can do it, but you will either need access to machines and tools to do the work yourself or you will need to spend the money to have someone fabricate it for you. The best looking way to do this IMO would be to design a new lim. Using the stock lim would look odd if you were to adapt that into something that would mount the blower, plus it would add a ton of height.
If you redesigned the lim, you could reposition the fuel rails outside of the runners to give yourself more space in the center so you could sink the blower down more. You'd probably have to make it 2 pieces unless you had it cast because it could be tough to machine out parts of the plenum with a normal opening on top for the m90.
Obviously the less work you can do yourself here (engineering, machining, etc), the more expensive this is going to get. But it certainly could be done. In the end, you'd be better off doing an actual l67 swap or just buying a 3800 car.
MonteCarloSS02
07-31-2014 08:49 PM
Jordanshedd5
03-02-2010 08:06 AM
One Dark SS
11-11-2009 11:34 AM
