cam?
Old 07-15-2012, 05:46 PM
augi's Avatar
Default cam?
I'm considering running a gt1 cam and pacesetter headers, I have a l26 manifold, no hv3, full catback exhaust... what else do I need for a cam install? Rockers? Rods? Lifters?
Old 07-15-2012, 08:19 PM
turbo monte's Avatar
Double roller to b safe. Be sure yo have the double roller machines to fit true to the block. Machined oil pump cover and Springs.
Honestly IMO don't bother camming a N/A its not worth it. Just top swap it. You will make more power with a top swap than that can will make.
Old 07-16-2012, 08:43 AM
Doing the work yourself? Then go for a CAM. But then you will want to port heads and start getting into some major work.
I'm gonna have to agree, just save up for a turbo kit. Then when you do the turbo kit and take the car down a little in the engine, do some rockers and springs
Old 07-18-2012, 08:24 PM
x3 on not bothering with a cam. For the price of a cam and headers, you aren't far away from a top swap.
Old 07-19-2012, 10:00 AM
augi's Avatar
I appreciate the feedback, but i not doing a top swap. I figured that a cam would be the best way to go until my car drops from daily status to weekend warrior, then i can do the turbo. Again, thanks for the advice.
Old 07-19-2012, 01:30 PM
nitehawkjcb's Avatar
Do a cam if you plan on going turbo in the future, just make sure the cam can be used for NA and boost.
Or this.
Old 07-19-2012, 01:45 PM
Or just wait until you turbo, this way before you do the turbo install you can take everything apart and redo gaskets
Old 07-23-2012, 07:00 PM
I was actually lookin into gettin an s1x cam. But i keep hearing to stay away from cams if i can't do it myself n stic roc rollers instead. What's the power difference between an s1x cam and 1.9 yella terra rockers? Pros? Cons?
Old 07-23-2012, 09:09 PM
Probably 15-20 HP, cams are soooo much better. More power, faster times. I'd like an XP Hot cam one day.
Old 07-24-2012, 08:44 AM
Pros of the rockers are just the ease of install.
A lot of cams can drop your MPGs a good amount. I would wait if you are still daily'ing the car
Quick Reply: cam?
