Blew a tranny
Old 04-17-2010 | 05:21 PM
phoenixdude24's Avatar
Default Blew a tranny
well technically not blown but its about a day away from being blown to pieces so its parked til monday when its getting swapped out for the upgraded one from an 04 Supercharged. 500$ total including parts and labor.
Old 04-19-2010 | 10:22 AM
yeyeee01's Avatar
wow thats no bad at all. make sure that one is going to last you a while and not break right away. Do you know the guy thats doing is because i think thats a good price.
Old 04-19-2010 | 10:27 AM
I wouldn't put the 4t65e-HD on your car unless you plan on boosting it.
The hardened parts in that transmission aren't the parts that break, and with the gearing on that one you will be slower.
You'll also need a new passenger axle.
Old 04-19-2010 | 11:36 AM
MAMONTE's Avatar
I agree, with the 4t65E HD, the only thing different about it is the differental. The interals are the same. The gear ratio on you non-HD tranny is 3.29, the HD one from the 04 S/C is a 2.93 gear ratio. So you will loose off the line pep. Not to mention need to change your differential.
Old 04-20-2010 | 07:51 PM
i was actually misinformed, its just from a regular 04 so its not the heavy duty version.
Old 04-21-2010 | 10:12 AM
haha good to hear.
While it's out you should throw a shift kit in there
Old 04-22-2010 | 04:10 PM
dspholmes's Avatar
500 with labor is still a hell of a deal
Montes4me
03-19-2013 07:10 PM
monte07
14
07-16-2010 05:02 PM
ltrain925
12-22-2009 12:39 PM
loudNproudSS
10-05-2008 05:18 AM
97z34
01-20-2007 02:30 PM
