Blew a tranny
Old Apr 17, 2010 | 04:21 PM
phoenixdude24's Avatar
Default Blew a tranny
well technically not blown but its about a day away from being blown to pieces so its parked til monday when its getting swapped out for the upgraded one from an 04 Supercharged. 500$ total including parts and labor.
Old Apr 19, 2010 | 09:22 AM
yeyeee01's Avatar
wow thats no bad at all. make sure that one is going to last you a while and not break right away. Do you know the guy thats doing is because i think thats a good price.
Old Apr 19, 2010 | 09:27 AM
I wouldn't put the 4t65e-HD on your car unless you plan on boosting it.
The hardened parts in that transmission aren't the parts that break, and with the gearing on that one you will be slower.
You'll also need a new passenger axle.
Old Apr 19, 2010 | 10:36 AM
MAMONTE's Avatar
I agree, with the 4t65E HD, the only thing different about it is the differental. The interals are the same. The gear ratio on you non-HD tranny is 3.29, the HD one from the 04 S/C is a 2.93 gear ratio. So you will loose off the line pep. Not to mention need to change your differential.
Old Apr 20, 2010 | 06:51 PM
i was actually misinformed, its just from a regular 04 so its not the heavy duty version.
Old Apr 21, 2010 | 09:12 AM
haha good to hear.
While it's out you should throw a shift kit in there
Old Apr 22, 2010 | 03:10 PM
dspholmes's Avatar
500 with labor is still a hell of a deal
Montes4me
Mar 19, 2013 06:10 PM
monte07
14
Jul 16, 2010 04:02 PM
ltrain925
Dec 22, 2009 11:39 AM
loudNproudSS
Oct 5, 2008 04:18 AM
97z34
Jan 20, 2007 01:30 PM
