6th Gen ('00-'05): Anyone have a bottle brush i could borrow/buy?
Old Feb 6, 2012 | 09:54 PM
bat208's Avatar
Exclamation Anyone have a bottle brush i could borrow/buy?
I'm trying to get my hands on a bottle brush hone. Looks like they're about $130. and right now money is really tight. i'm a post secondary student and moving really soon. i cracked a head gasket and im replacing it myself and would like to hone out the cylinders at the same time.
Does anyone on here have one i could borrow or where i could get one for a reasonable price?
Old Feb 6, 2012 | 10:11 PM
nemesis's Avatar
2009 Monte Of The Year
check with autozone or oreily they might have a loaner
Old Feb 6, 2012 | 11:18 PM
Would this work? 4" Engine Cylinder Hone
Old Feb 6, 2012 | 11:24 PM
PacerSS's Avatar
Considering our bore is 3.8" I would say that is too large. But it says works on 2" to 7". I don't know though the design just screams piston surface damage to me though.
Old Feb 7, 2012 | 08:23 AM
bat208's Avatar
The brush is supposed to be larger than the bore. They are spring loaded. So yes a 4" home would work
Old Feb 7, 2012 | 10:14 AM
PacerSS's Avatar
The brush you buy is already larger than the specified diameter. Which is why you buy a bore brush that is for your bore width not larger.
If I were you I would go with this one. And it's not even close to $130 so it should fit the budget.
http://www.amazon.com/95mm-Flex-Hone...8631399&sr=1-6
Old Feb 7, 2012 | 10:19 AM
I think the hone is more for a total rebuild. i didn't even think of that.
Old Feb 7, 2012 | 07:22 PM
PacerSS's Avatar
Honing is a good idea anytime you mix coolant/oil in the case of a head gasket leak this can create a pretty ugly sludge that doesn't do well in lubricating moving parts. Which could result in some wall scoring. But I rarely have seen this. It's always good to have the tool and not need it, then need the tool and not have it.
Old Feb 7, 2012 | 09:52 PM
bat208's Avatar
Amazon.com: 3 3/4" (95mm) Flex-Hone Cylinder Hone Tool 600 Grit (Silicon Carbide): Automotive
thank you for the link, and yes i was looking for the brush not the honer. to as you said clean it as well as give it a bit of a polish while its opened up
02ssLE
Feb 12, 2012 03:58 PM
Jan 7, 2012 03:11 PM
labnjab
Oct 14, 2010 12:51 AM
danmagdowski
Dec 21, 2008 05:39 PM
BeachBumMike
26
Nov 18, 2007 05:51 PM
