The Last Time I Let Someone Borrow My Monte
Hey guys,
BIIIG problems here. I let my wife's brother borrow my Monte Carlo for a week. Due to some family problems he had to make a trip that his car wouldn't make. Now, I'm all for helping out with her family. But, I was EXTREMELY hesitant to let someone drive my car. Hell, I barely even let the wife IN it. Against my better judgement, I allowed him to take it.
He drove it home to me last night, and I drove to work this morning. I made it about a block from my house before I had to pull over. It felt like my tire had a huge bubble on it. It felt like I was bouncing around while driving. So, I stopped and checked all 4 of them. I don't have any bubbles, but the outside of my front drivers side tire is worn down significantly more than the rest of the tire.
I (cautiously) made my way to work, and noticed that the feeling is most easily felt doing about 20-30 mph. After that, it smooths out until about 45-50mph. Then, smooths back out again. I didn't go any faster than 55, for fear of safety.
Now, I have been having some trouble with my ABS light, my TRAC OFF light, and my CEL, all coming on, and my "Service Traction System" message. Which, from what I read, is probably a bad sensor, or hub. Only happened randomly before he borrowed the car. Don't really think the two are related. But, that's the only other problem I've been having.
I'm really not too sure what could be my problem, or what he could've done to it. But, I am not a very happy camper today. Any, and all help would be great, guys! I'm really worried about driving my car like this.
I'm the same way no one & I mean no one drives my car! But my Hub also needs to be replaced. have the same lights and thing happen to me
Once it gets warmer I'm going to see what I can do... Try & leave your Traction turn Off. Hope things turn around for ya buddy!
Thanks for the quick reply, Chibi. I just skimmed over your "How-To" on hub replacement, and I suppose that I will have to go ahead and give it a shot.
Where did you get your assembly from? I can get a duralast from Autozone for about 93 bucks..Is that a decent price for one?
@Oh3 : That's what I had been doing prior to him taking the car. But, now, as soon as I drop it into gear the lights pop on. Are you having the "wobbling" problem as well? How long has your been like that? How safe is it to drive it like it is?
I agree with Cibi, sounds like you hub was beginning to have issues. If those issues were beyond just the internal ABS sensor, then the hub could have been causing spotty tire wear.
Perhaps the guy who borrowed the car drove it a little harder then you do, but if the hub was failing, it's tough to say what/who exactly caused that tire wear.
As long as nothing else it out of sorts, then it may not be the borrower's fault... I'd get the hub and tire changed.
As a side note, I'm neverous of who borrows my cars too (hence why it's almost never that anyone borrows a car from my driveway).
I agree with Cibi, sounds like you hub was beginning to have issues.As long as nothing else it out of sorts, then it may not be the borrower's fault... I'd get the hub and tire changed.
IDK about your wife's brother, but MY wife's brother ain't driving ANY of my vehicles. He's trashed a good 5 vehicles in the past 3-4 years. He's the type that *thinks* he know's what he's doing until he gets his car half apart and realizes that he's in way over his head. I don' think i'd let him drive a paper airplane let alone my monte!
Get a Timken from Amazon.
Does sound like a hub issue.If your getting that much vibration/wobble I wouldn't drive it.I've seen the end result of one when it gernade's an it's not cheap.My girls durango had a hub gernade an it took out the knuckle,rotor.pads,half-shaft,rim,tire,shock,an tie rod end.
