Any chips worth it
Old Sep 8, 2009 | 03:15 PM
smart move.
Look into saving up for the wiz-aired kit. VERY very good kit.
Old Sep 8, 2009 | 03:27 PM
paintballerr78's Avatar
were can i find a wizaired intake
Old Sep 8, 2009 | 03:35 PM
zzperformance.com
http://www.zzperformance.com/grand_p...=247&catid=113
There is the direct link, you'd want the standard option with the K&N intake cone. (+$44)
Old Sep 8, 2009 | 04:51 PM
paintballer i have something similar to what you have done, it helps until your engine warms up and then everything is virtually the same as if you had the normal air box
Old Sep 8, 2009 | 05:04 PM
03Monte's Avatar
this is not a true statement, you took your CAI off, and replaced it with a HAI...
you effectively raised the internal temps of your engine, which is not a good thing...IMO
you car may sound better, and may even have better throttle response, this is because the engine does not have to work as hard to get the air in, which normally would be a good thing, but now your pulling in air that is substantially hotter...increased heat can lead to KR, in stock form you have no way of telling if you have any KR, this is not a good thing...
KR can cause you to chip a piston, or worst case senerio blow the connecting rod and push your piston sideways in the cylinder...this would be bad...
trewyn15, i urge you to head the advice of myself, and the other members who posted in this thread...we are looking out for your own good (and your Monte's)
Old Oct 5, 2009 | 06:55 PM
Jomao_o's Avatar
This thread should be stickied.
I've learned so much in this thread, first off thanks for the pic of the ubend, and what a "ubend delete" is/was. thank you.
I am a new car owner and new to Monte's in general, thank you 03Monte and Chibiblacksheep for all of the great info and feed back.
I am very very glad i joined here. (Sorry, i dont know you guys' names.)
Old Oct 5, 2009 | 07:02 PM
Jomao_o's Avatar
Also Chibi,
In the link you posted with the Wizaired kit. this was at the bottom
<i> *Does not work in Bonneville or Impala/Monte's where the battery is on the driver's side. </i>
Now is this true, my monte's optima battery is on the right side.
I didn't know it, they changed positions.
Old Oct 5, 2009 | 07:06 PM
Jomao_o's Avatar
Sorry for the triple post, but nevermind it's on the right side when i'm in the driver seat :P
Old Oct 5, 2009 | 10:47 PM
woah damn im changing tomorrow til i can get a real intake lol damn...i didnt even realize, my old filter now is really dirty, should i just spray it out with compressed air?
Old Oct 5, 2009 | 10:59 PM
nitehawkjcb's Avatar
It shouldn't cost a couple of thousand for a top swap, I think ZZP sells an SSM90 kit for ~1,000 bucks. I suggest just saving your money until you can get supercharged - no other mod is going to give you gains like a blower will. Except nitrous, and that's garbage IMHO. As far as the Plog/ported manifold/downpipe goes, just get headers. Better gains and only a little extra money. SSAC headers are ~$400 FWIW.
