Antie-freeze leak? LIM?
Old Mar 13, 2012 | 10:03 AM
Steven73's Avatar
Default Antie-freeze leak? LIM?
I have seen antie freeze sitting behind the alt. between water-pump/engine. Soo i did the cheep fix first change the 7$ plastic elbows and the 2 o-rings on water lines to cab heator core... and puddle still shows up... 110 000KM S/c
Ive Read the bad storys on our stock poor LIM wanna make sure its the LIM.
Alum LIM gasket
6 INJ o-Rings
UIM gasket
oil change
can i keep throttel body on supercharger? anything els Ill need?
Old Mar 13, 2012 | 10:38 AM
Could just be the water pump gasket?
Old Mar 13, 2012 | 11:35 AM
Get a radiator pressure tester from your local loan-a-tool. Pump it up and inspect. I replaced coolant elbows once and had the o-ring not seat properly. Could be something that simple.
Also, did you ensure part of the elbow was not stuck in the intake?
Old Mar 13, 2012 | 06:23 PM
Steven73's Avatar
Im possitve i got all the peices of plastic out of the intake and the alt braket. Im im pritty possitve I got the plastic elbows seat properly I used lucas on o-rings and slid right in..
As for water pump gasket Its a possiblity. Bec Puddle is right at the lower intake manifold and at the water pump. But U can NOT see were its comming from Pressure testing. its just No rooms to look and point out...
Im sure best thing to do would be just change the hole water pump if gasket leaking.
By the sounds of it its pritty much time for a complete REBUILD lol. Ill do waterpump and poof intake gasket next... Dam I donno wat to Do.. dont wanna dump crap loads money intoo it Becase once weather warms up the tranny gonna start to act up...
MonteSquarlo
Dec 16, 2012 06:18 PM
spyderbite37
May 7, 2012 08:16 AM
goingforgold
Mar 8, 2012 05:16 PM
jasonsmith
15
Feb 7, 2012 09:17 PM
mcss01
Aug 4, 2005 10:19 PM
