anti freeze leak
Old Feb 14, 2012 | 03:11 PM
goingforgold's Avatar
Default anti freeze leak
my 2002 monte is leaking anti freeze. It appears to be coming from the top rear area on the drivers side. Is there any hoses in that area?
Old Feb 14, 2012 | 03:36 PM
Sparky-88's Avatar
No hoses, but could be something like an intake manifold gasket going bad. A picture is worth a thousand words as they say. Any chance you can snap a pic for us?
To help isolate the actual leak location, I'd suggest borrowing a radiator pressure tester from a local auto parts store (sometimes they charge a deposit which you get back upon return). It allows you to pressurize the system with the engine cold & not running so you can peak around with a flashlight to see where fluid is leaking.
Old Feb 14, 2012 | 03:38 PM
Possibly your TB gasket.
Also in that area are all your hoses and thermostat, but if it is further back then it could be the TB gasket.
Old Feb 15, 2012 | 12:12 PM
Got a pressure tester. It appears to be leaking at the rear top further back from the thermostat housing. Can't really get a pic theres to much crap in the way. I could barely see the leak with everything blocking it. I think I might have to remove some things to get a better look. Sounds like a weekend project.
Old Feb 15, 2012 | 12:15 PM
it's a 3.4 if that makes a differance.
Old Feb 15, 2012 | 04:56 PM
On the 3400, there is a black pipe that comes up from the water pump, runs along the front valve cover and makes about a 90 degree bend and shoots back (this is known as a heat tube, as it connects to one of the two heater hoses). Off of that are two tiny hoses that take coolant in and out of the throttle body (they run under the throttle body).
That might be an area to inspect (a mirror may help with that).
Personally, I dislike that concept of flowing coolant in and out of the TB. The early 3100 (that the 3400 is based off of) does NOT flow coolant in/out of the TB and works fine in many different weather situations.
Old Feb 15, 2012 | 07:53 PM
baja216's Avatar
I just had a similar thing with my '02. I recently replaced the thermostat. I found the thermostat housing was very slowly weeping antifreeze. I ended up taking it off, I replace the o-ring/gasket on the thermostat, and them applied some of that black permatex gasket maker to the housing.
I buttoned it up and as of tonight no leaks!
That may be the issue.
Old Mar 6, 2012 | 07:50 PM
Can you do a coolant bypass on the throttle body? If so how is this done?
Old Mar 8, 2012 | 05:16 PM
jimbo7's Avatar
If it's driver's side, more than likely it's the L.I.M. gasket
i've never had a 3.x liter gm that didn't have a leaking manifold gasket
MonteSquarlo
Dec 16, 2012 06:18 PM
spyderbite37
May 7, 2012 08:16 AM
Steven73
Mar 13, 2012 06:23 PM
03redTuscani
Aug 24, 2007 05:11 AM
Nortybignort
Jul 27, 2006 11:32 PM
