95 engine ideas??
Old Oct 4, 2012 | 06:53 PM
Boilermaker893's Avatar
Default 95 engine ideas??
I want to get more power out of my 3100 but I've seen you can't get a supercharger, any ideas??
Old Oct 4, 2012 | 06:57 PM
nitehawkjcb's Avatar
You could swap a 3400 top end, but you'd need to convert to OBD2 and need a wiring harness I + sensors I think. A lot of work for 20 HP... Maybe a Grand Am turbo kit? You're gonna have to do some fabrication regardless.
Old Oct 4, 2012 | 09:04 PM
I'm just looking for cheap stuff right now till I can build up some cash
Old Oct 4, 2012 | 09:08 PM
You're kinda limited... Maybe an intake and a PCM tune, that's about it...
Old Oct 4, 2012 | 09:22 PM
Where can you even get a pcm tune for a 3100..
Old Oct 4, 2012 | 10:29 PM
zzapultimate's Avatar
No such thing as cheap power.
Welcome to the slow world of 3100...
Old Oct 4, 2012 | 10:37 PM
You could probably get Milzy to do a tune, or go to 60degreev6 and ask them...
Old Oct 4, 2012 | 10:57 PM
I see milzy has 3100 pcms, but after what trewyn15 has said about his milzy tune, i dont know if it would be a good idea But yes welcome to the slow world of the 3100, not much you can do really
Old Oct 5, 2012 | 05:37 AM
Alright thanks
Old Oct 5, 2012 | 06:11 AM
Probably the BEST mod you can do is pull the 3100 and drop in a 3400. I know from of the early/mid-90's grand am guys did that. From what I've read NO PCM changes required in that swap and it works with your existing trans. The 3400 is a better performance build off the 3100 block and they are readily available.
86sschevyrider
Jul 8, 2013 08:10 AM
SpinEm_90
Apr 26, 2010 12:39 PM
kevin187
Mar 17, 2005 01:31 AM
kevin187
Mar 12, 2005 11:16 AM
earthquake
Feb 23, 2005 08:33 PM
