5.3L out of a GXP into an 03' Monte SS
Old May 29, 2007 | 09:19 PM
2003 SS's Avatar
Default 5.3L out of a GXP into an 03' Monte SS
Any suggestions? Will this work or should I just keep dreaming. Anyone have any success in doing this?
Thanks
Old May 29, 2007 | 10:56 PM
76MonteMan's Avatar
Default RE: 5.3L out of a GXP into an 03' Monte SS
You know, I've often wondered about this. I would love to see a 5.3L V8 swap into a 2000-2005 Monte Carlo SS. I wouldn't see why it wouldn't work. The engine bay should be large enough to fit it and the tranny is the same (except the V8 version is beefed up a little more). I would think all you'd really need to do to make it work would be to install the computer for the 5.3L. Now whether or not it is legal is another question.
Old May 30, 2007 | 07:52 AM
29MonteCarlo's Avatar
the wiring harness would be a killer... if its even possible. plus mounting brackets, exhaust, power steerting and AC hoses would all be wrong. way too much work. the 2000,2005 montes were not designed for the 8 cylinder engines.
Old May 30, 2007 | 08:23 AM
wiz kidd's Avatar
anything is possible...if you can put a viper engine in a pt cruiser then i'm sure you can do this...just probably be a lot of money..and all the electronic stuff would be a pain in the you know what......its not as easy as it was when you could drop a small block in anything
Old Jun 7, 2007 | 10:02 PM
Cowboy6622's Avatar
alright... heres some info for whyi would go down to the 3.9 to work with.... the police are doing it. so you ask why the police do it? because hp to weight ratio, its the best. plus, when you put the weight ofa V8 on a suspension designed for a V6... it'll work, but i don't want ot be with you if you take it over about 70. another thing... its FWD. If it was RWD, i'd be okay. fwd puts all the force at the front of the car along with all the weight. i woudln't want ot take a corner at over about 75-80 or the @$$ end will come around on you.
iMuf
30
Oct 22, 2013 04:26 PM
inssanity21
Oct 18, 2008 12:44 PM
RocknSS04
Dec 6, 2007 01:26 AM
BLACK ATTACK
Nov 5, 2007 06:51 AM
BeachBumMike
Jul 28, 2007 12:26 PM
