4T80e Connector Pinout
Old Feb 3, 2020 | 07:50 PM
WolvenScout's Avatar
Default 4T80e Connector Pinout
Alright, I finally got the transmission controller in the mail, but before I grab my soldering iron, I need wiring diagrams. I found a pinout diagram from an old grandpirxforum post, but other than that, I haven't been able to find anything useful. I have a 98 4T80e, and the number of connector pins as well as their layout match, but the wire colors don't correspond to the ones on my connector. I only need four wires, besides the positive and negative connections. The wires I need to locate are TCC solenoid, shift solenoid A, shift solenoid B, and line pressure solenoid. Does anoyone have some good diagrams/pinouts?
Old Feb 3, 2020 | 09:28 PM
I'm currently trying to find a free pdf download of a 98 olds aurora service manual, cause my 2000 monte carlo service manual has the trans connector pinout.
Old Feb 4, 2020 | 09:37 AM
Update:
I hit up Brandon Furches and he sent me this pinout, which I trust a lot more than the dated, blurry one I found earlier. He was also super helpful in answering some questions I had. A and B are both switched by negative, and share a common 12V. The 12V to the trans is connected to both E and U. The trans controller I have needs one conection for line pressure, which is pin C, the high side. But I'm not sure if the low side gets grounded. I need to check with the controller manufacturer. The trans also does not require a ground, just the two 12V connections.
Old Feb 5, 2020 | 09:55 PM
I don't know Brandon, but from what I have seen of his online posts and videos, he does great at sharing information. I know he's in the business of selling parts and performance builds, but he appears very approachable and happy to help (regardless of cutting a profit). Your info helps support that. Great people to have in the car community.
khel72
Nov 30, 2018 09:20 AM
JTaylor_88
Mar 30, 2016 09:20 AM
JC Colon
Mar 18, 2014 08:30 PM
Gib DTD
Apr 15, 2013 10:05 PM
94wrangler4.0
Aug 18, 2011 07:19 PM
