4t603 swap to 4t65e
Old Jul 4, 2011 | 11:41 PM
stillonly1's Avatar
Default 4t603 swap to 4t65e
Is there any wiring changes that needs to be done to swap from a 4t60e to a 4t65e? I have a 1996 Monte Carlo Z34 and want to swap the transmission from a 1997 Grand Prix GTP. Will the transmission bolt right up? Do the axles or computer need to be changed?
Old Jul 5, 2011 | 12:42 PM
z34phoenix's Avatar
the trany will bolt up, the axles wont. you will need axles from a 98, 99 Z34 monte. your computer and wire harness wont work. you will need a 97 computer and harness. also if you use a GTP trany the gear ratio in the trany will be very different.
it will have a 2.92 final drive vs the 3.43 that you have currently. i would actually recommend a trany out of a grand prix GT as it has a 3.29 final drive. unless you find a trany from a 97 Z34 you will need to have the PCM tuned for the correct gear ratio (97 Z34 4t65e's had the 3.43 gears) a lower number gear will help mpg on the highway but will hurt the low end acceleration of the car. i dont recommend swapping to a lower gear unless you have lots of mods or Turbo or SC.
I saw your other thread about the leak. but swapping to another type of trany is more work then needed. the amount of work required to swap to a 4t65e is about the same as doing a swap to a full GTP engine trany setup.
Old Jul 5, 2011 | 02:35 PM
stillonly1's Avatar
I dont want to go through that much trouble to change the transmission. I have just been reading up and everything says the 4t65e is a better and stronger transmission. My z34 is all stock and not looking to race. I just want descent power and reliability. Thanks Z34Phoenix!!! Think I will go another route.
ecosta221
15
Apr 18, 2014 06:30 PM
Overdose666
Nov 21, 2010 08:01 PM
nemesis
Jan 15, 2009 11:00 PM
mrl390
May 31, 2008 11:48 AM
88ss408
Jan 9, 2008 12:33 PM
