Speedo is too low, 87 LS
Old Nov 13, 2010 | 04:27 PM
toodles's Avatar
Default Speedo is too low, 87 LS
The speedo (and odometer) in my 87 LS is showing about 12mph lower than I'm actually going. Need to change the speedo drive gear, but don't know which I need (or which one I have).
I've searched a little on the net with few results. The problem is that I'm not exactly sure what to search for.
Do any of you guys have any knowledge of such things?
Thanks in advance.
Old Nov 13, 2010 | 04:42 PM
The Popcorn King's Avatar
Question...what size tires are you running out back?
Old Nov 14, 2010 | 04:31 AM
toodles's Avatar
I've got winter tires on now, they are 195 75/14. The summer tires are 265 50/15. I think they have the same circumference. It's an automatic transmission, three gears and overdrive.
Old Nov 20, 2010 | 10:00 AM
88ss408's Avatar
http://www.tciauto.com/Products/Tech...eedo_gears.asp
it sounds like you need to change your spedo gears. look at this chart and put your info
and it will tell you what gears to get.
Old Nov 22, 2010 | 04:14 PM
toodles's Avatar
Thanks for the link.
What's the difference between drive teeth and driven teeth? And how do I know how many teeth to put in?
Old Nov 23, 2010 | 12:25 PM
88ss408's Avatar
there is a gear on the output shaft of the trans.(the drive gear) and there is a gear on the speedo cable(the driven gear)
you may have to get them both.
TMoney
Aug 18, 2013 02:37 PM
Monteimpala
Mar 8, 2012 02:32 PM
StanzManianDevil
Feb 22, 2009 11:28 PM
StanzManianDevil
Dec 24, 2008 06:46 PM
mikeinparts
Jan 10, 2006 12:20 AM
