Engine Build: 350 build was for my MC but is finding a home in our Elco for the time being
Old Jan 24, 2024 | 07:18 PM
Budsjlm's Avatar
Default 350 build was for my MC but is finding a home in our Elco for the time being
Alittle back story.
Got this 350 15ish years ago from a buddy. He pulled it out of his k5 blazer because he was told it was a 305 my motor was toast and was a good running motor so I scooped it up
finially getting around to building it as the 305 in our Elco we picked up in April 2023 for our son to race it pretty tired, a lot of blow by
sold his jr and brought the Elco home within 12 hrs
he’s a pro at big car burnouts already
g body parking, yup 84 still in piece… had a kid that’s exspensive… kid starts racing that’s exspensive… soon my friend soon!
350 4 bolt to be built
I was going to toss it together and run it but checked the cam … it had seen better days
decided I better check the bearing glad I did!
this motor ran great in my buddies k5 I’m actually suprised at its condition
Old Jan 24, 2024 | 07:32 PM
Budsjlm's Avatar
this is a very budget build he can only run 9.0 in the 1/8th mile so going budget build get alittle closer to that than the 12.0 he running now I’d love to go wild but doing this on the cheap this time around
bearings where ugly!
pulled out the ol ring groove cleaner and got to work cleaning up the pistons
did a quick hand polish on the crank to clean it up
what a difference some elbow grease does
new bearings and rings installed, quick home to knock off the glaze on the walls
cleaned up valve train from the 416 305 heads from my 85 Monte cleaned up the intake and exhaust ports a bit, lapped the valves
Old Jan 24, 2024 | 07:41 PM
Budsjlm's Avatar
might as well call this build by summit budget build means summit branded parts for a lot of it
picked up a set of flowtech afterburner headers of market place for cheap, everything I’ve read they fit great in g body cars!
cloyes heavy duty double roller timing set
Summit 1102
Hydraulic Flat Tappet, Advertised Duration 278/288, Lift .421/.444
Decided to go with some roller tip stamped 1.5 rockers figured a nice little upgrade from the 40 year old stock ones
currant pile of things to go on, need to order oil pump drive and a timing cover
Old Jan 26, 2024 | 08:45 PM
Budsjlm's Avatar
Loaded up lastnight and painted this evening
Can’t help but get excited
Old Jan 27, 2024 | 08:21 PM
Happy to see you stop by! Been a while! Looks like some cool stuff going on!! The El Camino looks sweet!
Old Feb 3, 2024 | 06:41 PM
Budsjlm's Avatar
been a while figured I should swing by! Thank you feels great to be back in a g body
Old Feb 3, 2024 | 06:47 PM
Budsjlm's Avatar
timing cover, balancer, timing pointer all buttoned up
Top end of the motor is finially all buttoned up
oil pump drive, high volume oil pump, new pickup, oil pan all buttoned up
soon we can move forward on the removal/install,
electric water pump, alt and power steering brackets, flywheel and mini starter, and valve covers are on the list next to be ordered well over multiple orders
Old Feb 5, 2024 | 07:37 AM
zucchi's Avatar
Originally Posted by Budsjlm
If you plan on frequently R&Ring the headers, disregard the following suggestion.
If, like me, you dread having to constantly retighten header and collector bolts, I enthusiastically encourage you to use Nord-Lock wedge-locking washers.
I used these when I installed a new set of headers three years ago and haven't had any loosening issues. I should have used these when I first put headers on some 30-years ago.
Old Feb 6, 2024 | 10:41 AM
Dude, that looks so NICE!!!
Old Feb 8, 2024 | 05:47 PM
Budsjlm's Avatar
Here's a youtube video of how they work
That’s actually an excellent idea, I use a much larger version on my peterson wood grinder at work to keep the nut tight for the teeth. I do plan on nut and bolt checking this thing frequently since my 14 year old races it, not only my life but his depend on it
Thank I’m pumped
Sean Buick 76
Jul 11, 2022 08:28 AM
Peter Garami
Aug 6, 2019 05:21 AM
Leonardo Brocato
Jun 27, 2019 10:29 PM
Mallet
Jul 1, 2007 09:08 PM
saluteTOme
Jun 10, 2007 09:13 AM
