76 Monte build
Old Jul 8, 2022 | 05:12 AM
Sean Buick 76's Avatar
Default 76 Monte build
Hi guys,
im doing a friends 76 Monte at the moment. It’s a minty fresh 80,000 mile car. Fully loaded model with swivel buckets 350/350 etc. Does anyone know a header model number that fits these cars properly? I see lots of headers listed to fit but I’m scared to order them and run into poor fitment. I will post pics soon.
in the meantime here is my buick
Old Jul 11, 2022 | 08:28 AM
zucchi's Avatar
First off, you'll need to change out the transmission crossmember in order to install true dual exhaust, something like Summit Racing SUM-770322.
I used Hedman Hedders #68290 in my 1974 Monte Carlo with a SB 350, cast iron phase II bow-tie angle-plug heads, stock suspension and steering, factory a/c, and automatic trans.
These headers installed with less hassle than I expected.
The instructions said I needed a minimum of 36-inches clearance and I needed to unbolt the engine mount on the driver's side and raise the engine on that side two-inches so as to install that side's header.
I only had about 16-inches using jack stands. To my delight, the driver's side installed with no hassle or dimpling. I had to remove the starter to install the passenger side header. It seems to me if I had 36-inches of clearance, i.e., a hoist or pit, I wouldn't have had to remove the starter. On top of all that, there's no interference with my angle-plug heads.
If your application has AC, I recommend you get a Hedman Auto Air Conditioning Bracket, #20110, and use Proform Self-Locking Wedge Header Bolts #66753. They use Nord-Lock wedge locking washers. I've had them on my car for nearly three years and they do not come loose.
Leonardo Brocato
Jun 27, 2019 10:29 PM
RocknSS04
Jun 7, 2010 06:26 PM
Twin_Turbo
Jun 5, 2010 10:14 PM
zipper
Apr 15, 2010 11:12 PM
RocknSS04
May 27, 2009 09:25 PM
