3400 injectors?
Old Sep 17, 2008 | 02:08 PM
vita's Avatar
Default 3400 injectors?
I was thinking of a way of getting a few more HP for not too much bank and though, hey, could I swap out my injectors for a bit more HP? A good change of the wires?
What do you guys recommend? If yes, any products you think I should be looking at?
Old Sep 17, 2008 | 04:43 PM
88ss408's Avatar
Default RE: 3400 injectors?
i don't really think that changing your injectors will get you much H.P unless they are already @ there limit's because most of them can push more than they are set for stock.
i think that 00+ 3400 injectors are 55lbs @ idle so with a tuner you should be able to bump it up some
but if you want more than the stockers can give try some l67 ones you will need a adaptor to make them work
http://wot-tech.com/shop/3400/l67-in.../prod_119.html
Old Sep 18, 2008 | 10:06 AM
How would bigger injectors give more power? They are typically setup for 80% duty cycle stock, meaning you have more headroom horsepower wise before your injectors goes static at WOT (the point where you must upgrade injectors). If you put in bigger injectors- its just going to open them for a shorter period (lower duty cycle), and you will end up with the same power.
New plugs/wires won't help either- the stock ones are perfectly fine.
What are you refering to with the 55 lbs? They're not 55 lb/hr injectors- they're much smaller. Also, his fuel pressure should be lower than that at idle- not to mention, you can't change fuel pressure with a tuner- I thought it was a normal return, FPR style system on his car?
Old Sep 18, 2008 | 12:13 PM
88ss408's Avatar
ok my mistake on the lbs thing i ment psi
a stock 3400 96-99wot @42psi and a 00+wot @56psi
and yeah you have to change the pressure at the fpr the tuner would be to pulse it longer
Old Sep 22, 2008 | 11:18 PM
vita's Avatar
hmm, well, any ideas on how i could bump up a few HP by doing some of the minor tweaks? any recommendations?
Old Sep 23, 2008 | 12:48 AM
Try www.milzymotorsports.comthey are one of the few companies who support that engine.
The bad thing, is the $/hp on upgrades is pretty bad with the 3400. I would say a pcm tune (or buy a tuned drop in pcm) would be decent- about the only other real easy mod is like a CAI/FWI, and a ported TB, and then minor exhaust work.
The way to make any decent power changes on any NA engine is heads/cam- and both of these are expensive and difficult to do.
Maybe a 3100/3400 expert could chime in to help suggest more cheap/easy mods that are worth doing.
Old Sep 23, 2008 | 09:05 AM
88ss408's Avatar
check them out
http://wot-tech.com/shop/3400/cat_35.html
they have everything you will need for a 60*V6
and yes the prices are a little bit more expencif than most aftermarket places becuase they are not mas produced but everythigng is good Q. and it works
Ron A
Jan 29, 2012 10:28 AM
malletboy
Oct 9, 2010 12:13 PM
Nasal
Sep 23, 2006 11:58 AM
malletboy
May 20, 2006 10:30 AM
maclawa
13
Feb 20, 2006 12:30 AM
