3.8 supercharger question
Old Sep 19, 2008 | 08:07 PM
v8_Killa's Avatar
Default RE: 3.8 supercharger question
so swaping the hd for the regular tranny in a supercharged monte would make for better passes?
Old Sep 20, 2008 | 12:18 AM
It would make it a bit quicker in the 1/4, but there is really no point. IMO, its not worth all the effort of swapping transmissions- not to mention the cost for a couple tenths off in the 1/4. Its one thing if your current trans was toast and you needed a new one anyways, but I certainly wouldn't pull a perfectly good trans to do this- you could pick up the same amount of time with cheaper mods depending what level you're at.
Old Sep 20, 2008 | 10:52 AM
v8_Killa's Avatar
oh i was just asking my monte is na for the time being anyway nice to know i got the better tranny just trying to see were i can drop my next 300$ in to
Old Sep 20, 2008 | 03:59 PM
I woudn't say your current trans is necessarily better- they are so close to identical that I wouldn't say one is any better than the other.
However, the current trans you have (the regular 4t65) will be a pinch faster- and you will have an easier time swapping to a performance torque converter later if you ever choose to do so.
Old Sep 20, 2008 | 06:02 PM
sprfrk2005's Avatar
ok i have been down this road as well and i am just now seeing this site where they provide the full kit that is a great site and very valuable way of buying the parts IMO dont have to go out and start a scavanger hunt for the parts in a junk yard. I would have a couple of questions in relation to the top swap. It would be, by getting the top swap would it be safe to install a shift kitto the tranny and getting your PCM tuned?
Old Sep 20, 2008 | 10:59 PM
I'm confused- what difference would the engine have whether or not its safe to do a shift kit?
A shift kit is just fine as long as you don't go for the hardcore setup (the really long spacers with the super stiff springs)- there's no reason to be going around banging every gear so hard it feels like the car is gonna fall apart- at least not on a street car; but any normal shift kit would be just fine.
You need to have your pcm tuned (or use an L67 pcm) for a swap anyways, but pcm tuning is always a good thing if the tuner is good. Thats pretty generic across any vehicle/engine combo.
Old Sep 22, 2008 | 04:36 PM
3800monte's Avatar
thanks 4 all the help
Johnp84
Sep 12, 2013 03:27 PM
TMoney
May 8, 2013 10:34 AM
BlackRainSS
Apr 12, 2012 08:45 PM
BlackRainSS
Jan 31, 2012 09:35 PM
tlip06
Feb 24, 2008 10:34 AM
