1999 monte LS TCC problems..
Old Jun 8, 2009 | 09:44 PM
nymphetamine876's Avatar
Default 1999 monte LS TCC problems..
I have a 1999 Monte carlo ls with the 3.1 in it. It has TCC problems, but i dont know where to start in order to fix it. The car has 116k on it. Ok so here is the problem: When i am cruising between 35-45 mph and in 4th gear, the TCC seems to have difficulty choosing when to lock and unlock and when this happens, the tac goes up and down 500 or so rpm's. If it does lock, it locks very hard and you have to give it a lot of gas to get it to unlock again (i.e. going up a hill). It will do the same thing on the freeway between 60-70 mph, the tac will go up and down and the car surges back and forth. I am almost thinking its the TCC solenoid or the Pressure control solenoid. What do you guys think? Is this a common problem with the 4t65-e tranny's?
Thanks,
Alex
Old Jun 9, 2009 | 04:57 AM
Hi `Alex, and Welcome to the MCF Family
When was the last time you had your trans serviced ?
Fluid/Filter changed ?
Check back on your thread/post to see what other member's
suggest/post on your problem.
Some Transmission Shops will check 4 `free, but
check them `out for their reputation before you sign anything.
Wish you Good Luck & a resolve 2 your prob.
Look 4-ward to your future posts & pic's of your Monte.
Old Jun 9, 2009 | 08:41 AM
i havnt had the tranny fluid changed since ive had it, and ive only owned it for about 5 months now. I have checked the fluid however, and it looks normal and does not smell burnt. I am planning on replacing all the shift 'noids and TCC and pressure 'noids to see if that helps, along with changing the fluid. If that doesnt help, then im stuck.
Old Jun 9, 2009 | 09:07 AM
Check out the below links & see if it helps with your prob
Good Luck
4T65E Transmission Info
Below you will find a few of the common problems plagued by the 4T65E and what causes ... Another common problem / concern of this transmission and more ...
www.tripleedgeperformance.com/4T65E_Transmission_Info.php - Cached - Similar pages
4T65E Parts
4T65E Bushing Kit, $29.99, This is a complete bushing kit to replace any or all worn bushings inside the transmission. There are a few very common wear ...
www.tripleedgeperformance.com/4T65E_Parts.html - Cached - Similar pages
More results from www.tripleedgeperformance.com »
Old Jun 9, 2009 | 10:32 AM
When you change the fluid get Dexron 6, instead of the stock 3. It runs cooler.
And yes, those are common problems with these transmissions.
Old Jun 10, 2009 | 08:32 AM
So i havnt changed my transmission fluid yet, which i will probably do by the end of this week, but yesterday i drove it around the block a few times just to get things warmed up. now i used a *white* paper towel this time to wipe down the transmission dipstick and not only did red show up, but dark grey. could this be clutch material? am i screwed?
chris yates
Jan 13, 2014 05:00 PM
killerBee
May 4, 2013 12:45 AM
StrongTakeover
Sep 26, 2011 08:44 PM
kennyjohn
Nov 23, 2010 03:22 AM
caffeinegamer
Mar 3, 2007 06:41 AM
