1999 Monte Carlo Turn signal problems
Old Apr 16, 2009 | 07:17 PM
kennyjohn's Avatar
Default 1999 Monte Carlo Turn signal problems
Hi
I have read some of the previous posts but this one has a new twist to it. The left turn signal will stay on all the time,not blinking,just lit up,and this is random. The left turn signal will flash and at the same time the clock info,will flash along with the turn signal,in perfect harmony. This is driving my son nuts.
Any help or direction is appreciated!
I donot know where the flasher module is,I can locate the fuse,but I donot know if these are valid places to start.
Thanks
Old Apr 17, 2009 | 11:16 AM
vincenti's Avatar
was the radio recently replaced with an aftermarket unit? or anything else electrical replaced around the same time you started having this problem? I learned the hard way one bad ground can cause all kinds of electrical problems in areas you wouldn't expect.
Old Apr 19, 2009 | 01:02 PM
kennyjohn's Avatar
Thumbs up
No But after checking a few things I noticed the front sidemarker lites out. I found the left socket all rotted out. I removed the bulb,what was left of it and the turn signal stated to work fine. I will replace it and see what happens.
Thanks for your response.
Ken
Old Apr 19, 2009 | 01:24 PM
dominic's Avatar
same thing happened to me last week.it turne out to be the turnsiginal bulb needed replaced
Old Nov 19, 2010 | 02:02 PM
eclipse98's Avatar
Originally Posted by kennyjohn
Hi
Thanks
Hey there, I recently have been experiencing the same exact problem, i was wondering if you came across the problem
thanks
Old Nov 19, 2010 | 03:36 PM
skylark65's Avatar
always start simple & cheap and work your way up from there. when my turn signals were effed up i started with the bulbs, then checked the fuses & relays ( underhood & on the passenger end of the dash) then tested the flasher (WAAAY up under the dash on the drivers side), and eventually wound up replacing the multifunction swich in the steering colum with a new one, 'caus the old one was the root of the problem. it not only messed with the turn signals but i would also loose my brakelights, because they are both wired through the swich.
Old Nov 22, 2010 | 11:39 PM
Originally Posted by anyuta34
The premier Asian toronto asian escort escorts provider toronto asian escorts in the Toronto area, we bring you the best in Asian and oriental female escort service. We have toronto escort seductive and sexy female toronto escorts escorts to satisfy our client's needs.
spammer, who the hell let this get by???
Old Nov 23, 2010 | 03:22 AM
well it is late monte carlo 3831 I'm sure it will all be gone tomorrow
jedimcca
Oct 24, 2025 01:30 AM
trey0503
Apr 27, 2018 11:39 AM
fueldude00
Oct 7, 2012 08:33 AM
80 Monte
Aug 16, 2009 12:55 AM
Nortybignort
Jul 25, 2006 10:35 PM
