TCC Solenoid
Old May 2, 2013 | 05:43 PM
killerBee's Avatar
Default TCC Solenoid
Check Engine light came on. Code P0742. Is it hard to replace? Its on side of transmission correct?
Old May 2, 2013 | 06:13 PM
turbo monte's Avatar
it is easy if your good with working on cars but takes a lot of work to change. this solenoid is under the transmission side cover so you have to tare into the trans a little to get to it. here is a good write up on how to do it.
GM 4T65E solenoid shift valve replacement TCC/PWM EPC 1-2 2-3
Old May 2, 2013 | 09:44 PM
nitehawkjcb's Avatar
The actual replacement is easy. Getting to it is another story. You either have to drop/lower the cradle to get the trans cover off, or pull the engine/trans to get access to it.
Old May 3, 2013 | 08:49 PM
killerBee's Avatar
Are these the correct solenoids? And while its apart should i install transmission shift kit?
4T65E Transmission Solenoid Kit GM Volvo Shift TCC EPC New 2003 on 99150 | eBay
GM Chevy 4T65E 4T65 E Transmission Shift Kit 1997 Up | eBay
Old May 3, 2013 | 10:19 PM
I recommend calling Dave Norris at triple edge performance for all this stuff.
The shift kit goes in the bottom of the trans under the trans pan not under the side cover where the solenoid is located.
Old May 4, 2013 | 12:45 AM
I got all 4 solenoids from autozone and have had no issues.
StrongTakeover
Sep 26, 2011 08:44 PM
nymphetamine876
Jun 10, 2009 08:32 AM
mrl390
May 31, 2008 11:48 AM
2003supersport
Apr 25, 2008 11:54 AM
2003supersport
Apr 25, 2008 12:50 AM
