4th Gen ('81-'88): 1984 monte carlo ss
I just got a 1984 monte carlo ss. I have done a full tune up and replaced and repaired a few things that needed to be done. i cant figure out why when i go from park to drive or drive to park the car kind of jerks/jumps. can anyone tell me what might be the issue? thanks
It is idling a little high I'm sure a new carb wouldn't hurt. I was thinking elderbrok1406 600cfm. But I wasn't sure if I really needed a new one. I'm no mechanic and the one I have has serious labor fees. What do you suggest
at one time i owned a 1986 monte carlo ss, first thing i would do that is going to be cheap, is replace all the vacuum lines. who knows when or if they were ever replace, the hoses have to be hard as rock and cracked. A vacuum leak can cause all kind of weird problems, even the one you have now.
The carb. you are thinking of getting would be a great fit. do not go any bigger then the 600 cfm. Do you know of a good place that can rebuild a carb? Cause rebuilding would be the why to go , would save some money, but theses days it is VERY HARD to find someone who knows how to rebuild a CARB.
Chassis Dyno Tuning Carburetor Repair and Adjustment Denver Colorado
Click above link
Also, have you used a good carb cleaner ?
<table width="570" style="text-transform: none; line-height: 12pt; text-indent: 0px; letter-spacing: normal; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal; word-spacing: 0px; -webkit-text-stroke-width: 0px;" border="0" cellspacing="0" cellpadding="0"><tbody><tr style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"><td width="560" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;" colspan="3">
Carburetor and choke cleaner quickly and effectively removes fuel system gum and varnish deposits. Carburetor and choke cleaner is safe for oxygen sensors and catalytic converters and will not leave any residue.
</td></tr><tr style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"></td><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">
</td><td width="510" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">High-pressure spray quickly removes fuel system gum and varnish deposits without leaving any residue.
</td><td width="40" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"></td></tr><tr style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"></td><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">
</td><td width="510" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">Cleans carburetors, automatic chokes and PCV valves in seconds.
</td><td width="510" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">Oxygen sensor and catalytic converter safe.
Less then $5
Good Luck
</td></tr></tbody></table>
Click above link
</td><td width="510" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">High-pressure spray quickly removes fuel system gum and varnish deposits without leaving any residue.</td><td width="40" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"></td></tr><tr style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"></td><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">
</td><td width="510" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">Cleans carburetors, automatic chokes and PCV valves in seconds.</td><td width="40" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"></td></tr><tr style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;"></td><td width="10" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">
</td><td width="510" height="10" align="left" valign="top" style="line-height: 12pt; font-family: Helvetica, Arial, Geneva, Swiss, SunSans-Regular; font-size: 10pt; font-style: normal;">Oxygen sensor and catalytic converter safe.Less then $5
Fiky206
Sep 28, 2007 08:33 AM
Sydwayz
Mar 22, 2007 10:14 PM
