04 S/C Monte Carlo gas gauge
Old Oct 31, 2013 | 02:07 PM
04IntimidatorSS's Avatar
Default 04 S/C Monte Carlo gas gauge
so the past couple days my gas gauge has been acting up I started it once and the needle spun all the way around and now the needle with fluctuate from time to time car has 55k on it..anybody have any ideas what it could be?
Old Oct 31, 2013 | 03:58 PM
Lorenzo's Avatar
Most likely the fuel level sensor has gone south. You can pick up a dorman one and replace it! Your able to access the fuel tank from the trunk so its a pretty easy fix
Old Oct 31, 2013 | 06:58 PM
Since you mention the needle spun around, I am suspecting the stepper motor in the instrument cluster is failing. These motors in the cluster are fairly common to fail unfortunately.
I know there is a write up on MCF regarding how to change them.
ladybridgeport
May 29, 2020 08:20 AM
02montels
Oct 22, 2011 08:39 AM
iMSeRiOuS
Jun 21, 2010 09:08 PM
phal
Jul 21, 2008 08:41 AM
BeachBumMike
Jul 30, 2007 11:53 AM
