01 SS Mis-Firing under load
Old Aug 3, 2009 | 03:57 PM
xman23's Avatar
Question 01 SS Mis-Firing under load
Hi all,
I posted earlier about my overdrive going out over a year ago. In 2 weeks i plan on replacing the tranny and just today the car has started to misfire (chugging)(like it has a hard time going) under acceleration. Once the car warms up it is not as severe, but still exists. If I place the tranny in neutral and hit the accelerator there is no misfiring. Because of the governor I can only test under neutral up to 4000 RPM.
Is there damage to one or more cylinders because I have driven without that gear for over a year?
Thanks for any guidance
Old Aug 3, 2009 | 05:13 PM
I wouldn't think you damaged the car by driving without overdrive, unless you were driving very hard on the car.
and stop revving the car in neutral / park, you can damage it that way!
When was the last tune-up, has your fuel filter been changed? Maybe you are experiencing a clogged cat? If it was a misfire it should be throwing a code.
Old Aug 4, 2009 | 03:45 PM
monte07's Avatar
thats what im having again with mine. i still have a warenty and they said they didnt find any thing but a code and they erased it. i said did the tech drive between 35 to 45 normal driving they said no and i said thats when it happends. thats why i came here to fix it because of the warrenty. im still p.o. about it. in away im glad gm is going out in a blaze of glory because what the dealer techs are doing not fixing custimers cars. like chevys i have two others runs great but im upset because i like my monty carlo
Old Aug 4, 2009 | 04:05 PM
MAMONTE's Avatar
Ingnition coil, clogged cat, fuel filter, and or simple tune up (spark plugs and wires)....sounds like it could be something from the above list.
I doubt you ruined the car by driving a year without OD, because even without OD these cars are geared tall, so you were no really over reving the car...but I would fix that ASAP. Its certainly not good for your car to do an extra 1,000 RPM all the time, and is in no way good for your gas milage.
OneLeg1993
Dec 17, 2013 09:41 AM
Bradster61
Aug 21, 2011 12:27 PM
jfavfox
Oct 13, 2008 06:24 PM
MIKE07083
Aug 19, 2007 09:00 PM
Slofobic
May 6, 2006 10:59 AM
