Synthetic Oil worth the extra cash?
Old Aug 3, 2009 | 02:59 AM
Frosty LS1's Avatar
Default Synthetic Oil worth the extra cash?
Lately I've been reading up on Synthetic oil as an engine life extender, and slight power booster. They say synthetic oil can add anywhere from 3-10HP and 3-10 lbs of torque, depending on your make and model. Also, it's more efficient at lubricating the engine and keeping it cooler so it prolongs engine life. The best looking one out there now is Royal Purple. I'm almost fully convinced to go with it, just to pump out a few extra horses and let me engine have a few extra thousand miles, BUT I've heard that synthetic oil is more prone to leaks since it has a higher viscosity. Currently my car, a 2003 Monte Carlo SS N/A 3800 has 62,000 miles on it, the oil has been changed regularly. Is this a good idea? Any chance of leaks? Will a small power gain like this matter at all?
Old Aug 3, 2009 | 03:10 AM
Hope the below article helps in your Decision.
Your Choice ?
Synthetic Versus Conventional Oil
Viscosity, Temperature, And Horsepower
Photography by Marlan Davis
http://www.carcraft.com/techarticles...oil/index.html
^Source infor from above link ^
It may pour like water, but Mobil 1’s new Tri-Synthetic 0W-30 motor oil was worth 10 hp and 15 lb-ft of torque over conventional 20W-50 oil in this 392 Ford. Synthetic oils like Mobil 1 reach the engine’s vitals faster than “dinosaur” oils, protecting them while reducing starter and battery cranking loads.
Red Line oil offers an extensive line of synthetic lubricants, including straight-viscosity race-only synthetic motor oils. Its products are well known for their performance under extreme temperature conditions, resistance to shear, and strong antiwear properties.
Quaker State offers synthetic/conventional blended motor oils that offer many of the benefits of fully synthetic oils but with more affordable pricing. Full-synthetic premium oils are also available from Quaker State.
Pennzoil originally developed Penzane X2000 to meet the specialized needs of the aerospace community for a lubricant that’s stable in the extreme conditions of outer space. Now it’s available for automotive use, incorporated in Pennzoil’s line of synthetic 5W-30, 10W-30, and 5W-50 motor oils; ATF; and gear lubricants.
Over the years, Car Craft has tested many different types of engine components. A common theme underlying many of these tests is that bigger is not necessarily better, especially on the street. But just as many continue to believe in rad cams and giant carbs, traditional, thick, single-viscosity oils still have a strong following among car-crafting traditionalists.
Of course, high-viscosity oils don't flow well at low temperatures. In the old days, guys living in cold climates put in a thinner oil for the winter with a "W" or cold temperature-viscosity rating. Although they poured better at low temperatures, straight-viscosity "W" oils, in turn, didn't do a good job of protecting high-performance engines once they reached normal operating temperatures, so they weren't recommended for sustained high-speed driving. The oil industry developed "all-season" multiviscosity oils to solve the problem, but some of the early products didn't hold up under heavy-duty operating conditions, tainting the reputation of multiviscosity lubricants among many Car Crafters to this day.
Yet today's modern oils are vastly improved over those of 20 years ago. For oils that meet the current "SJ" service designation, viscosity breakdown is no longer a significant problem, thanks to modern formulation technologies and viscosity enhancers. Auto manufacturers have also redesigned their engines for tighter clearances and instituted precision machining techniques that take advantage of thinner oil to deliver improved fuel economy through reduced friction.
Like the OEMs, racers have discovered that friction reductions plus precision tight clearances yield greater efficiency and more power. Racers also know that most engine wear occurs at start-up, so it's critical that engine parts receive proper lubrication as soon as possible--hence the need for an initially thinner, so-called "winter" viscosity. Today, few racers run a single-viscosity motor oil except nitro-burners. According to 76 Lubricants, most NASCAR teams use the really thin stuff during qualifying, moving up to 20W-50 during the long race (although it's rumored some teams may use the extreme cold-weather thin oils all the time, but don't want to admit to their latest performance "trick").
Synthetic oils, pioneered in the '70s by Mobil and now available from most major oil companies, take the all-season, multiviscosity approach to the outer limits. Unlike traditional mineral oils that are produced by distillation and further refining of existing crude oil stock, synthetic lubricants are made through chemical reactions. These new oils aren't synthetic or artificial in the sense that they're manufactured out of whole cloth--they still have the same natural ingredients found in "real" oil. But in a synthetic lubricant, these ingredients are recombined like a Lego set to yield synthesized-hydrocarbon molecular chains with desirable characteristics and uniformity not found in even the highest-quality traditional motor oils. Typically, the best synthetic oils use a combination of up to three different synthetic base fluids--polyalphaolefin (PAO), synthetic esters, and alkylated aromatics.
Because a synthetic oil's molecules are much more consistent in size and shape, they are better able to withstand extreme engine temperatures. By contrast, the unstable molecules in conventional oil can easily vaporize or oxidize in extreme heat. Mobil 1 synthetic is said to be capable of protecting engines "at well over 400 degrees F"; in the real world, most racers have no problem running synthetics up to 290 degrees F under prolonged use, but they get really jumpy when a conventional exceeds 270 degrees F.
Because a synthetic oil is chemically produced, there are no contaminants in the oil. By contrast, conventional oils contain small amounts of sulfur, wax, and asphaltic material that can promote detonation as well as varnish and sludge buildup. With no wax, synthetics will flow at much lower temperatures than conventional oils. In fact, synthetic oils are now available with viscosity ratings as low as 0W-30, as in Mobil 1's new Tri-Synthetic blend or Castrol Formula SLX. These oils flow more than seven times faster than a conventional 5W-30 motor oil during initial start-up, yet at normal operating temperatures act like a regular Grade 30 oil.
An 0W-30 synthetic oil is capable of pumping easily at -62 degrees F and flowing at even lower temperatures. Conventional oils are essentially frozen solid at that temperature, so there's simply no conventional equivalent to this new grade. There are 5W-30 conventional and synthetic oils, but even here, the synthetic has a real-world advantage: Mobil 1's 5W-30 will pump at -58-degrees F, compared to about -35-degrees F for a conventional oil.
But claims and talk are cheap, so Car Craft had Westech Performance run some of the new Mobil 1 0W-30 in Ford's prototype 392 small-block stroker crate engine. The Mobil 1 was compared to the generic (and recommended for this engine) 20W-50 factory-fill conventional oil, as well as 10W-30 conventional oil. All tests began with the oil temperature stabilized at 210 degrees F. The engine ran from 3,300-6,200 rpm, and several runs were made for each oil to ensure repeatability.
In terms of peak numbers, we found that the engine gained nearly 7 hp with the thinner conventional oil, and was up nearly 10 hp with the synthetic. No peak torque gains were observed by changing from 20W-50 to 10W-30 conventional; however, the synthetic was up 15 lb-ft of torque at the peak. Looking at average numbers helps explain where the gains occurred--both the thinner conventional and synthetic oils broadened the torque and power bands overall, but the thin Mobil 1 showed the greatest improvement under 4,700 rpm, indicating that the thinner oil provides less initial drag for the engine to overcome.
However, thinner oil also translates to lower oil pressure: The 0W-30 oil developed 10 psi less than the baseline 20W-50. Only 46 psi was on tap at 6,200 rpm--kind of shaky as most gearheads like to see at least 10 psi per 1,000 rpm. Still, the engine ran OK, and the bearings looked fine on teardown, seemingly verifying synthetic manufacturers' claims that their products' greater shear strength more than makes up for lower viscosity. Is 10 hp and 15 lb-ft worth paying two to four times more for a quart of oil? Or the potential for extended engine life? You be the judge.
Old Aug 3, 2009 | 04:18 AM
Click above link
Check out our MAIN MCF SPONSOR
AMSOIL
AMSOIL- "Our Company makes the Best Lubricants in the world, period, and challenges anyone or any company to prove us wrong! That won't happen because our competitors know it's true."
A. J. Amatuzio, President and CEO.
Includes some great information.
Check it out & support
Thanks
Old Aug 3, 2009 | 07:27 AM
drewskie043's Avatar
i think you will be fine switching over to synthetic. there are lots of discussions on the MCF about this so I would recommend using the search tool to help you make your decision. one of my favorite things about synthetic is it doesn't turn to molasses in your engine on -20F days here in MN. it keeps it's viscosity so it's great for winter starting.
Old Aug 3, 2009 | 10:11 PM
Frosty LS1's Avatar
What's the RS badge kit? Like Rally Sport? But for a Monte Carlo? I'd be interested in that, if it looks right.
Old Aug 4, 2009 | 12:58 PM
MAMONTE's Avatar
Go with synthetic....I have never used anything else in my Monte, and i've swithed an engine with over 200K from regular to synthetic! Synthetic is WELL WORTH the money.
I use nothing but Mobil 1 in the Monte, and Shell Rotella T synthetic 5w-40 in my truck.
Wal-Mart is a great place to buy your oil and filters for great prices.
Old Aug 4, 2009 | 01:01 PM
MAMONTE's Avatar
Its a custom decal kit that you can buy for the 06-07 Monte. I got mine from the Chevy dealer, and they installed it.
Old Aug 4, 2009 | 05:57 PM
my next oil change i'm going with Q horsepower from quaker state. $18.99 at walmart. it's a pretty good buy for a name brand synthetic oil.
Old Aug 4, 2009 | 07:08 PM
Frosty LS1's Avatar
I haven't done much research on Quaker State, but this Friday I'm getting a K&N high flow oil filter and 4 1/2 quarts of Royal Purple synthetic motor oil. The guys at Advanced Autoparts couldn't recommend Royal Purple more, even over Mobil 1 which was only $1 less per quart, they say you get what you pay for, and Royal Purlpe is about $8 per quart. I'm not expecting to feel a power difference, but I'm still hoping for one. xD
mudweiser
Dec 5, 2011 02:25 PM
nebstewart07
Jun 19, 2009 08:38 AM
c_ingram38
Apr 16, 2008 04:20 PM
pitter05
Dec 7, 2007 01:55 PM
SoDak98Monte
18
May 17, 2006 10:40 PM
