head linners
Old May 27, 2005 | 11:41 PM
04MonteLS's Avatar
Default RE: head linners
ORIGINAL: mickey
true never thought of that,
normally the stuff they put under headlinners is of high density foam but i bet i could make low dens. work just have to buld the flames in to somethign like chop borad or somethign like this under the foam to give them teh height i would need to give the right effect. have to see what i can find for this.
Thanx for the idea
You just want foam for the flames, right? If so, I don't think you'd want a high density foam as you'd have to do alot more forming of the foam before you covered it.
Old May 28, 2005 | 06:20 AM
mickey's Avatar
Photobucket
this si true but i think if you had real soft foam that when you streched your fabric over it you would have the problem of them not looking right anywmore
Old May 28, 2005 | 06:23 AM
04MonteLS's Avatar
ORIGINAL: mickey
I think a soft Tempur foam would be perfect, if not, medium T foam at most.
Old May 28, 2005 | 06:41 AM
mickey's Avatar
Photobucket
kool thanks will see what i can find around here
Old May 28, 2005 | 02:09 PM
benhillzone3's Avatar
yeah i would go with the t foam cause once you pull your fabric over hit i think that i twould support it he best to give yout helook that you are looking ror.
Old May 29, 2005 | 12:26 AM
04MonteLS's Avatar
ORIGINAL: benhillzone3
spellcheck owns you
Old May 29, 2005 | 04:51 AM
mickey's Avatar
Photobucket
thanks ben. and yeah i was thinking the same thign i want a stiff foam there
but i figured i would give it a shot to see if i could get it from a med supply if i can get somethign that i think it stiff enough i might try it on a scarp pannel to test it out
ChibiBlackSheep
Apr 22, 2015 05:09 AM
04MonteLS
15
Aug 26, 2009 05:41 PM
04MonteLS
31
Apr 3, 2006 01:44 PM
big green dog
May 30, 2005 02:52 AM
Mc9C1
Oct 25, 2004 10:23 PM
