Has anyone else had this problem?
Old Nov 6, 2010 | 03:37 PM
matt210's Avatar
Default Has anyone else had this problem?
My issue is that one of my tabs for the rear defroster has fallen off. Everywhere i go thinks im talking about the grid being broken. i have found a few different products online. one of which i have a good feeling about. here is the link - http://www.frostfighter.com/prt2000.htm - its 28 dollars. My question is, has anyone else had this problem? And if so, what was your remedy of the issue? All help would be greatly appreciated.
Old Nov 7, 2010 | 01:18 AM
Enzo354's Avatar
STILL SLOW
I think you have to sauter it back on. I could be wrong.
Old Nov 7, 2010 | 10:08 AM
monte07's Avatar
enzo is right on that if it is the little tab it can be soulder it back on. if it is one of the lines in the window you might need to check each line andsee if the volt meeter is getting voltage. if it is one of the lines you need to get some type of liquid patch type of thing that alowes curent threw it to allow the window heater to woek i forgot what it is called
Old Nov 7, 2010 | 10:11 AM
monte07's Avatar
if the tab came completly off the back window like what the web site you posted showed thats how you fix it but those tads break in half notcompletly come off the window its very rarely does that
Habbibie
Aug 29, 2014 08:36 AM
dan1313
Sep 16, 2011 09:54 AM
irulesoha
Jul 21, 2010 10:06 PM
NTIMD8T
May 4, 2009 09:32 AM
monteriderLS
Aug 15, 2008 12:55 PM
