Engine Cover and Bay
Old Jun 1, 2011 | 05:13 PM
wiseheak's Avatar
Default Engine Cover and Bay
I've been looking into painting my engine cover. I bought some high heat duplicolor engine enamel just to be safe, and its a little bit brighter than the color of my car so that it wouldn't look so dark. I'm also planning on cleaning some of the rust up as well.
The one thing I don't like is how nasty the metal between the engine cover looks. What would be the best way to clean that up?
Old Jun 1, 2011 | 05:24 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
It's aluminum right? I would probably remove it and clean it thoroughly with a grease cutter like dish soap. Then I would hit it with an aggressive sandpaper (Like 80 grit) until I reach a smooth layer of metal. Then I would rub it down with a slightly less aggressive paper (like 150 grit). Then I would clean it again and use a high fill primer to remove any sanding marks. Then I would paint! Good luck!
Old Jun 1, 2011 | 08:29 PM
wiseheak's Avatar
Alright thanks, I'll give it a try!
Old Jun 7, 2011 | 03:38 PM
wiseheak's Avatar
Here's where I'm at so far with the paint job, I tried the Vaseline trick on the silver lettering but I didn't put enough on so the paint started to chip on the silver lines which I'm going to touch up. It's a little lighter than what I was lookin for but it's growing on me. I also want to eventually paint the slots at the top of the cover black. Any more ideas or feedback would be great!
Old Jun 7, 2011 | 03:55 PM
03Monte's Avatar
from the pics it looks like tar heel blue, you a NC fan by any chance lol
you did a great job on it, and i think everything that duplicolor makes is crap ;-P
the top of the intake looks pretty good as well, the easy way to get the rest of that out is to just have it blasted with 120 Alum oxide.. then you can throw a nice contrasting color on it!
Old Jun 7, 2011 | 04:29 PM
Looks Nice..
Old Jun 7, 2011 | 07:54 PM
wiseheak's Avatar
haha I didn't even think of the tarheels, i was just thinking that the metallic blue wouldn't be much of a difference. I'm in MI so I suppose I could have painted it yellow for U of M =P
Thanks for the feedback
Old Jun 7, 2011 | 08:03 PM
looks good!
Old Jun 7, 2011 | 08:04 PM
Very nice!
MJClemm
Mar 31, 2014 12:27 PM
Tride
Oct 2, 2013 12:47 PM
Mrcrowley5
Oct 16, 2012 07:44 PM
01 Monte SS
Jun 10, 2012 11:12 PM
04MonteLS
18
Sep 14, 2005 08:35 PM
