p0440 code and strong gas smell in cab
Old 10-31-2009, 03:40 PM
rockieg00's Avatar
Default p0440 code and strong gas smell in cab
[FONT="Comic Sans S"][i have/FONT]i have a 2000 mc ss that is putting out p0440 code also has a strong odor of gas in cab cant find the vapor leak
Old 11-02-2009, 09:27 AM
P0440 is a problem with your EVAP system.
Old 11-03-2009, 01:37 PM
rockieg00's Avatar
Ya i know ..been knowing that..but thanks..just gotta find out where that smell is coming from ..next im gonna check the fuel pump
Old 11-03-2009, 01:43 PM
How has your MPGs been? Could be a problem in the system, not necessarily a leak, but is causing your car to run very RICH and causing you to smell the excess fuel?
Old 11-03-2009, 06:11 PM
Enzo354's Avatar
STILL SLOW
Take off your cover and check the clip right behind the engine on the fuel line, Mine was leaking down by the headers!!! Youll just need an o-ring for the fix.
Old 03-18-2011, 05:50 PM
I know this is an old thread but will reply to the issue of strong gas smell.
My '03 had such a strong gas smell coming from the rear I swore it would have been discovered as a leak somewhere. It nearly brought tears to my eyes how strong an odor. Driving behind the vehicle was very bad.
Once one of the three coils were replaced the strong smell of gas went away.
spark plugs/wires were left as is...only one of the coils was the root cause.
I assume the smell in the car was due to the smell coming from any leak in the exhaust or the smell being sucked into negative pressure from inside at speed (wow....I really dont know what I just said!).
-John
Bkm1981
08-18-2015 08:20 PM
tridski
10-03-2014 07:45 AM
02montecarlo
10-11-2011 03:06 PM
Joe Bloggs
12-02-2009 09:55 AM
yzf125
06-22-2007 07:02 AM
Quick Reply: p0440 code and strong gas smell in cab
