Ignition Switch
Old 08-16-2013, 09:00 AM
Jimmy Criswell's Avatar
Default Ignition Switch
I have a 1985 Monte Carlo SS. I am having an issue with getting it started. There is nothing when the key is engaged to the start position. My question is where is the ignition switch located on these cars. I can see all of the ignition wires going into the colum. I just cannot locate the ignition switch.
Old 08-16-2013, 10:52 AM
03SSLE's Avatar
The switch is affixed to the inner column by a couple of screws. Look on the column near where it mounts to the underside of the dash.
Old 08-16-2013, 11:47 AM
Awesome, thank you for the pic. We are in the process of trying to find out where we are losing power out by tracing the wires back.
Old 08-16-2013, 02:51 PM
Default Crank Fuse
Does anyone know how the crank fuse is labeled?
Vette139
03-28-2020 08:11 AM
jrjfam
09-18-2013 01:59 PM
03ssMonte
06-24-2007 09:15 PM
trigger
06-12-2006 04:05 AM
soldout162000
03-24-2006 12:34 AM
Quick Reply: Ignition Switch
