Repair Guide: Vehicle Speed Sensor Replacement
.......the other guages are working properly. And after doing some on-line research and asking around at work; I think that this is the issue. The speedometer will act like it should for a little while, while driving but when I have to stop or shift gears ( reverse...3rd....or ingaging the OD ) the speedometer starts jerking and then just sticks. It read 30mph while parked in my driveway after a day trip one day. I've done the switch to ACC then ON then back to OFF and that works sometimes.
I've raised the front end up and removed the wheel/tire. Gotten under it and still cant remove it. I may remove the inner wheel well and see if that will help ?
Thanks guys.
Thanks guys.
vss
Well, after 3 tries and breaking the connector plug to the vss I had to take my car to my mechanic and he was able to install the new vss and a new connector. He commited just how hard it was to work in that area. So far, it appears to have solved the issue. I hope that I don't have to order a new stepper motor ?
Anyone have a wiring diagram of the VSS and the electrical connector? I have a 2004 3.4L and my speedometer doesn't work. I have taken it in and had the speedometer rebuilt, put in a new VSS but still doesnt work. Only thing I can really think of doing is changing out the connector but dont know where it runs to. Anyone have a diagram of where the VSS connector runs to and how to switch it out?
i'm looking at replacing the VSS in the rear driver assembly, but if its not the sensor and it is the wiring harness, its very hard to follow.
also does anyone know where i can purchase rear left wiring harness for VSS, i can only find front end harnesses.
Even dealership can't find it in their computers, they're useless
THis thread has been dead for a number of years. Many of the members are no longer active. I see you started a thread but it's asking for ground locations. I suggest starting a new thread explaining more about your problem, what you have done and the help you are looking for.
11-02-2013 02:07 AM
Repair Guide: Front & Rear Wheel Speed Sensor Replacement
montejass
FWD Tech Guides '95-'07
18
08-11-2013 06:12 PM
