water/meth inject kit anyone?
From the research I have done the xp hot cam is a better cam than the xpz and the xpz is slightly bigger better for torque, the guys at zzp are the worst customer service but 3 of them I contacted all said xp hot cam over the xpz. When I went to my shop for the dyno of course it was the most humid day of the week so that didn't help at all and beside the guy had a small industrial fan not a big one in a warm shop. I probably will go for the bigger intercoolet but I am currently broke. I was originally going to get that one but wasn't happy I would have to fabricate it to fit and move the altenator according the zzp. I'm buying a fenderwell Intake next week so I'm sure that will help a bit Untill I get 1500$ for the intercooler. I really hope your right and I gain more power from it, it won't be installed probably for another 2 months.
Bigger intercooler will cool more to let you run a smaller pulley to make more power. Once you drop a pulley so far Wil need a belt wrap kit to help with belt slip and then soon you spin the sc out of its efficiency range and you need a ported gen v to help compensate for that. Best bet for you is save for a ported gen v and a intercooler for a gen v and then install both together.
Second, this is the setup I wanted and at the time I didn't consider cost of fabricating the stage 2 Ic to fit as well as with the altenator relocation.
Please don't be intimidated by the alternator relocation bracket, it's nowhere near as complex as it sounds. I just had to install one on my monte when I switched to the 99+ style alternator setup. Wiring still reaches just fine, you just install a spacer under the front leg of the alternator.
Like I said earlier go on YouTube and look up endsle that's the guy with the same setup but bigger ic stage 2 heads and gen v blower on e85 mix and with 60lb injectors, and I'm putting down more whp.
The shop I go to is great the owner knows a thing or 2 about modding cars especially domestic his fbody currently running 1200whp that he built himself, sick watching it on the dyno
Even a relatively mechanically unskilled person could go to a junkyard, buy a used coolant reservoir, place it in any open place under the hood, and plumb it in (it's really just 2 hoses- in and out). For a speed shop that builds 1200 hp fbodys, sourcing and installing a simple reservoir, even on your current setup, should be a cake walk.
Speaking of pulley size- here is a good article I found on ZZP's website about their cams:
Which Cam Should I Buy? - ZZP News
ZZP claims 320-330 whp out of their smaller VS cam, and that's without ported heads. They claim you can run a 3.1 or 3.0" pulley with heads/headers and NO IC at all, and as low as a 2.6" with an IC.
For the XP cam, they also claim you can run a 3.1" with basically no other mods than the cam (implied), a 3.0" with other mods like headers/heads, and a 2.6" again with an IC.
That really reinforces my early point about pulley size. I don't have a lot of personal experience with tuning/modding XP cars, but it certainly sounds like you're probably a few steps too big on pulley size for your mods.
6th Gen ('00-'05): Water Meth injection
Ace25
06-19-2013 08:38 AM
