At wits end
At wits end
I have a 96 with a 3.1, it won't start in the cold, but I have replaced the ignition module. It ran all day, sat all night, no start. replaced the spark plugs ran all day, sat all night, no start. I am baffeled any Ideas?
I would think it is like a bad cell in you car battery or a bad alternator go by Auto Zone and see they will check it for free if you have one close by or Napa they will do it for free also my guess is a bad cell in your car battery though
Hi NeedaSmoke,
Sorry 2 read about your problem...When it does not start (is it cranking & just won't fire ?)....
Have you tried taking `off a plug wire to see `if it's getting spark ? Please post as much infor as possible about your problem, because all we have is your posted words to be able to make suggestions on what may be wrong...
Please check back often on your thread question to see what some of our expert tech member's suggest...
Wish you Good Luck 4-Sure in gett'in it running great again.
NeedASmoke Here's a few smokes as your prepare your next post with more infor
Car needs 3 basic things to start/run, air-fuel-spark. You say it's getting fuel and spark, how about air? Is the air filter plugged up?
Now, the other thought, i think Blazed mentioned was battery/alternator. Maybe even corrodoed connections on the started/alternator.
When it does NOT start, does it sound like the starter is doing anything? What do you do to finally get it to start? If you say "jump start the car", I would immediately suspect battery or corroded connections.
I'm not sure if a fuel pump failure is possible in cold weather. I'm not sure if GM has this on all cars (or where it is on other cars), but my '94 Grand Am has a "test" lead. All you have to do is jumper the test lead to the positive connection on battery and you should hear the fuel pump "hum", which is a simple check that it's working.
Sleeping Martyr
04-28-2012 05:35 PM
Sleeping Martyr
04-20-2012 12:24 PM
