Water Spots?
as does driver #3,I too use a silicon blade water remover,works great to get most of the water off the car then a shamois for the rest. I too have very hard water. my son bought me a Mr.clean spotless car wash kit at walmart, it works ok but Ive gotten to where I usually go to Car Spa, get the 5$ wash or more, then come home and detail it myself! just lazy I guess!! throw the drying guy a couple of bucks and they dry better and do the tires with protectant!!
There is a cleaner that my father always used for tires called Wesley's tire cleaner which does a super job on White walls and if you want to get all the slick stuff from the tires that builds up this works good for that also. It kind of does the work for you, spray it on, rinse it off clean, use a brush for better results.
