Too wide
Old Feb 5, 2007 | 01:48 PM
turner_dtp's Avatar
Default Too wide
whats the widest i can go with rims on my 02 montecarlo without having to mess with other things? does putting rims mess your brakes up?
Old Feb 5, 2007 | 02:25 PM
wiz kidd's Avatar
Default RE: Too wide
i'm pretty sure 8.5's will fit...which is the most common when you get to 20" rims..i wouldn't go any wider than 8.5 for the rim
Old Feb 6, 2007 | 12:05 AM
04MonteLS's Avatar
ORIGINAL: turner_dtp
I have no firsthand experience with this, but I'd imagine you'd want to stay as close to 8" wide as possible.
Old Feb 6, 2007 | 04:38 AM
mickey's Avatar
as far as them messing up your brakes, I have never seen a wider or even a talle rwheel tear up anything as far as Mechanically .
NOW!!
the larger the tire gets the more rolling mass you have so think of it this way the larger the mass the harder it is for those brakes to stop it.
So a brake up grade is always a good bet for the new 20's etc... that are out .
other wise you will have to stop a block a head of time becuse you will roll that far.
also make sure even if you dont upgrade the whole system to at least get a good quality set of pads for the brakes. so you know they will help stop you some also.
deeboe
Mar 30, 2010 10:29 AM
BUDDZZ
Jan 3, 2010 03:41 PM
JBreu
Mar 5, 2009 07:52 PM
96MonteCarloLS
Jul 6, 2008 06:22 PM
zwc0442
Jun 4, 2008 10:37 AM
