Tires/Rims
Old Dec 4, 2009 | 01:28 PM
llafup1's Avatar
Default Tires/Rims
Where can I find a good set up factory sized Rims (aftermarket bulit style) for MC LT 2007? and can the 17" get any wider and still not rub? i.e. 6", 7" 8" etc...
Old Dec 4, 2009 | 04:56 PM
RocknSS04's Avatar
Why stick with 17s, and not go with 18s or bigger? Your car comes with a short tire, and 1st off I would recommend going to a bigger tire. Stock is a 225/55-17, 7.0" rim, 7.1" tread width, 26.8" tall, & 26 lbs. Where an SS uses a 235/50-18, 7.5" rim, 8.3" tread width, 27.3" tall, &27 lbs.
I personally run 245/45-18s in the summer, and 235/55-17s in the winter (on my '04).
A 245/45-18 has TONS of room, fits a 8.5" rim, 8.5" tread width, 27" tall, but 29 lbs. You can go taller and wider, but they get heavier FAST.
Compare wheels here:
http://www.tirerack.com/wheels/resul...ar=&sort=Brand
And check out tire spec's for tire size info here, as an example (my summer tires):
http://www.tirerack.com/tires/Spec.j...255WR7F1GSD3XL
Remember, you can counteract tire weight by selecting lighter wheels.
Please note also that bigger isn't always better. Example: Check out the above link for both 245/45-18 & 255/45-18. Same dimensions, but more rubber, 2 lbs more rubber at 31 lbs. The 255 is overkill, and will affect ride, performance, AND gas mileage.
Good luck, and let us know what you pick, or if you narrow it down, show us what you have in mind.
Old Dec 11, 2009 | 08:54 AM
llafup1's Avatar
Just basically looking for stock tires and rims (after market) in bulit style, Can't seem to find any in that size 17"
Old Dec 11, 2009 | 09:14 AM
Check out our new MCF Sponsor
It's a great company & site for tires/rims etc
click on below pic : )
Featured Sponsors
http://www.tirerack.com/upgrade_gara...LT&autoModClar=
Above link is for a 07 Monte Carlo LT (Hope it helps) 4-Sure
Let us know what U decide...Good Luck
BeachBumMike
Jun 7, 2014 12:58 PM
GoodZwell
Feb 21, 2013 08:22 AM
MIKE07083
Aug 29, 2007 07:23 AM
BeachBumMike
Aug 19, 2006 09:08 PM
big green dog
Feb 24, 2006 11:26 PM
