Could Save your `Life or those U `Love ?
Old Dec 11, 2009 | 06:18 AM
Question Could Save your `Life or those U `Love ?
Knowledge is Power & could save your life `if you take the time to inspect/check your tires or check the tires of the ones you love....
There are Several links below to read & learn about the HIDDEN DANGERS of tires.
Post your comments/Share your knowledge with your Monte Carlo Family...Thanks
Do You know the age of your tires ?
The Hidden Danger - New Old Tires
Have you ever gotten a great price on new tires and wondered how can this tire be new? Well the answer might be that you just purchased old but UNUSED tires. The problem is that tires, like any rubber product, degrade over time and could present a significant yet hidden safety risk regardless of tread depth.
The danger of old tires has been known since at least September 2003 when the British-based Tyre Industry Council issued an unprecedented warning that previously unused tires should not be sold if they were more than 6 years old, and that all tires should be replaced 10 years after their manufacture.
It is curious that European and Japanese automobile manufacturers warn of this danger but NOT U.S. tire manufacturers. For example the Volkswagen manual states “WARNING - old tires can fail in use, causing loss of vehicle control and personal injury. Replace tires after 6 years regardless of tread wear.”
If the U.S. tire industry is refusing to give you the same warnings that are given to car owners in Europe and Asia, how can you protect yourself?
The answer is that cryptic bunch of numbers on the tire sidewall. The last 4 numbers at the end of the 12-digit DOT serial number will tell you when you tire was manufactured. But you need to know the 4-digit code and until recently the DOT serial number was located on the inside of the tire requiring you to crwal under the car to read the number. Here’s the code — the first 2 numbers are the week of manufacture and the last 2 numbers are the year of manufacture. For example: 1404 means that the tire was made the 14th week of 2004, or mid-April of that year. If the last group of digits has only 3 numbers then your tire was made before 2000. “219″ means the tire was made the 21st week of 1999.
Before you buy that next set of tires be sure to check the last 4 digits of the DOT serial number, and to be safe right now check any tires you currently have in service on your vehicle. If they are more than 6 years old, replacement may be in order. Aged tires can separate without warning and cause catastrophic results.
Yes it is curious that something as important as tire safety would require you to get on your hands and knees and know the secret code but until better regulations are in place this is the only way you can be sure that you and your family are safe riding on those tires.
Old tires/ Hidden danger | Fairfax, Virginia Car Accident Lawyers ...
Nov 1, 2009 ... Old tires/ Hidden danger. The tires on your car might be putting your ... and to be safe right now check any tires you currently have in ...
barreralawfirm.com/2009/11/01/old-tires-hidden-danger/ - Cached
SAFTY ALERT: Aged Tires: A Hidden Danger on the Road? - SlickDeals ... SAFTY ALERT: Aged Tires: A Hidden Danger on the Road? ... Check the code on the tire which can tell you the year and week a tire was manufactured. ...
m.slickdeals.net/forums/showthread.php?t=869970 - Cached
]The Hidden Danger - New Old Tires | The Consumer Warning Network Jun 24, 2008 ... The Hidden Danger - New Old Tires. June 24, 2008 ... Before you buy that next set of tires be sure to check the last 4 digits of the DOT ...
www.consumerwarningnetwork.com/.../the-hidden-danger-new-old-tires/ - Cached - Similar
Or go to our New Sponsor & they will check for you : ) ?
Old Dec 11, 2009 | 08:49 AM
demonspeeder1's Avatar
This is definitely a good thing to know. Thanks Kidspace.
Old Dec 11, 2009 | 08:57 AM
...Thanks for your post & it's great 2 C U visiting your Monte Family : ) Would luv 2 hear a vid of your straight pipe V8 AweSome Monte Carlo 4-Sure...Wish U & Member's a Happy/Safe/fun Holidays....Check your tire codes `ok : )
<~ Space `Out
Spaced `Out 2day...Just observed found your link & it's WIld Crazy...Thanks
http://www.youtube.com/watch?v=8vpdlZrme3s
Old Dec 11, 2009 | 09:24 AM
Haha. Thank you. : )
Nov 12, 2014 06:40 AM
Jan 28, 2012 07:09 AM
Dec 6, 2011 06:55 AM
Oct 18, 2010 09:56 PM
MAMONTE
Aug 30, 2009 09:58 PM
