Ticking Noise While Moving
Old Nov 25, 2012 | 12:08 AM
iMSeRiOuS's Avatar
Default Ticking Noise While Moving
When I'm driving I can hear a ticking noise (coming from the wheel well)
The noise goes away when I'm pressing on the brakes.
(this noise was present before changing out the hubs & is still present after)
Any ideas on this?
Old Nov 25, 2012 | 04:23 PM
iMSeRiOuS's Avatar
could this have to do with the control arm bushing? I was told mine are tearing
Old Nov 25, 2012 | 09:51 PM
Try jacking up the wheel you believe the noise is coming from. Rotate it by hand. Do you here the noise? If yes, take the wheel off, rotate the rotor by hand. Do you here the noise? If yes, inspect everything on the car, if no, look for anything that might be on the rim or coming in contact with the rim.
I've heard bad CV joints may cause this (but I have not experienced it first hand).
jeff2425
22
Jun 5, 2008 12:25 AM
PsuBrock
Feb 9, 2008 11:05 AM
ivory317
Dec 27, 2007 10:39 PM
96montecarlo
Jun 9, 2007 08:42 AM
87monte
Jan 25, 2007 05:14 AM
