7th Gen ('06-'07): Rear tire touching strut
Old Mar 26, 2022 | 01:14 PM
SSblack06's Avatar
Default Rear tire touching strut
My drivers side rear tire is touching the bottom of my strut housing that holds the spring.
The car alignment is dead on the rim and tire size is 235/50/R18 on 18" alloy rims.
Cn anyone tell me how to solve this issue? I bought some 1/4 inch spacer but lugs are to short.
Old Mar 27, 2022 | 11:18 AM
Jeffs02rwdSS's Avatar
Sounds as if you have the wrong offset of wheels on the car. A spacer is probably the only solution at this point. Getting longer studs installed into the hub's is definitely the cheapest route .
Old Mar 27, 2022 | 01:03 PM
Are they aftermarket rims - if so, what are the specs? Thats stock tire size and wheel diameter so they should fit with stock wheels or aftermarket wheels with the right size.
As mentioned above, you can buy extended studs. Ive got some from ARP. But it depends how bad they hit if thats an option or not.
Old Mar 28, 2022 | 05:53 AM
SSblack06's Avatar
Thank you for your reply. I took the car to a suspension shop for a inspection, and found out that the drivers side rear strut is bent. The struts are less than a year old.
So I will have a replacement installed. Again thanks for your time and response
Old Nov 10, 2022 | 01:58 AM
koladx's Avatar
Was able to do it all myself with stuff I had in my garage! Saves me hundreds.
Tutuapp 9Apps Showbox
BLKMonte00
Jun 10, 2017 09:38 AM
dragonmyst
Feb 22, 2015 10:13 AM
Chris NSarah
Feb 21, 2014 06:04 PM
jaws2008
Jul 28, 2010 06:55 PM
retr0kickz
Jul 5, 2009 11:10 AM
