Rear struts are bad
Old Apr 19, 2012 | 04:23 PM
brendan127's Avatar
Default Rear struts are bad
Will these fix the problem? Are they easy to install yourself or will I need to go to a shop?
KYB - KYB GR2/Excel G Struts #
Old Apr 19, 2012 | 04:47 PM
Budsjlm's Avatar
yes that will fix your problem, if you have some mechanical knowledge you can do them with hand tools
(how to)https://montecarloforum.com/forum/how-section-30/5th-6th-7th-gen-rear-strut-replacement-28934/
or you can have a shop do them
Old Apr 19, 2012 | 08:39 PM
BlackRainSS's Avatar
Should be a easy enough job by yourself and for a shop.Either way it should fix the problem.
Old Apr 19, 2012 | 08:44 PM
There pretty easy to install ive got the same on my monte just need some tools & a spring compressor
Old Apr 19, 2012 | 09:04 PM
Budsjlm's Avatar
Don't forget to replace your top plates(mounting plate, bearing plates ect, different places call it different things)
Musicman217
Jul 30, 2014 06:03 PM
TMoney
Apr 9, 2014 09:32 AM
mastercon_00
Oct 27, 2012 04:54 PM
BankheadSS
Aug 11, 2008 05:49 PM
2003 SS
Apr 15, 2007 11:39 PM
