New brakes on a budget
Hey, lately I have been noticing that my brakes haven't been able to stop me like they once could, they have been screeching, and they are giving off a lot of brake dust.. It's most likely time for new brakes but, I have a small budget. I make a max of about 200 bucks a week at my current part time job and about half of that gets spent when I try to save it. I need some help finding good brakes that are quiet, and good quality that won't have me spending $500 on them. Pads and rotors all 4 wheels probably. Any Suggestions?
From the factory design...Less rotateing mass.for fuel economy etc...
Only older models have enough "Meat" to get them turned...
General rule of thumb..new pads...=....new rotors.. to do it correctly...On these new model vehicles!
YOU CANT PUT A PRICE ON "SAFTEY" !!!
You can get all four corners done for under $200 if you get some cheapies off of ebay. I have some from brakemotive on my car. Most people don't recommend getting cheap brakes because they can save your life. I honestly haven't had a problem with mine though. Rotors are rotors now a days.. almost all of them are made in china anyway.
Your rotors are warped if your car shakes when you apply the brakes. You need new rotors.
I personally have never had a set "turned" before. I've only replaced them once in the 30k I've put on the car so I felt it would be beneficial to spend a little more and just get new rotors vs. turning the old ones. Just my opinion though.
X2, it's time for new rotors.
Go to rockauto.com and check what they have.
They have it broken down by budget/performance/OEM/etc.
I just did front brakes and rotors on the Monte (typically those are the rotors that warp). I picked up Centric Premium Blank rotors for $50/ea and then I grabbed some Bendix Ceramic pads for $30 (I bought on Amazon using RockAuto's part numbers, because free shipping). Spent $130 on the fronts and installed them on Saturday.
Typically your back rotors don't really warp, you could get away just sanding the surface of the rotor (in a crosshatch) and just changing the pads for another $30
I just did rotors and pads on all four wheels on my Monte. All parts from RockAuto.com. Everything I bought was from the "high performance/heavy duty" heading.
Bendix Ceramic pads (I wanna say about $30 per set), AC Delco Advantage Rotors (agian, I think about $30 per wheel). I believe after a RockAuto coupon code and shipping I was around $200. I LOVE the set I have on the Monte right now. Well worth it, and cheaper then buying from the local parts stores....
