Max 15" tires on a 1986 MC
Old Aug 2, 2005 | 03:39 PM
Monte Python's Avatar
Default Max 15" tires on a 1986 MC
Ok i had a buick regal before my Monte, someone had 4 15" brand new tires so i swapped them to my Regal and it was a bad mistake, everytime i hit a bump the tires would hit the wheel wells and when i made a full turn the would scrape etc.....
Well, my boss has a 68 Camaro and he wants it stock so he said i can have the 5 star chromes that are on the car now but im worried that scraping will be the issue with the Monte, so my question is what is the max size of 15" rims i can put on it?
Old Aug 2, 2005 | 07:15 PM
rchurch's Avatar
Default RE: Max 15" tires on a 1986 MC
You can measure the offset, height, and width of the ones you have on it now and compare them to the new ones, or just bolt them on and see how they fit. Thats probably what I would do, cuz I'm more of a visual person than a mathematician.
Old Aug 2, 2005 | 07:56 PM
04MonteLS's Avatar
ORIGINAL: Monte Python
what do you mean by "the max size of 15" rims"?
Old Aug 8, 2005 | 02:56 PM
ORIGINAL: 04MonteLS
What i mean is the numbers on the tires, example 205/75/14, those number explain the width, tire height etc... correct? Im trying to find which 15" tires would not cause a scraping issue, because if the camaro's tires are too wide or high and will cause a scraping problem i wont take them.
I just dont want to find out once its too late!
Groucho
May 28, 2009 06:48 PM
RocknSS04
May 4, 2008 03:01 PM
Submariner
Mar 31, 2008 09:03 PM
CHEVYRIDINHEAVY
Mar 7, 2007 11:09 PM
