Lowering the Monte
#51
Ok here is the parts list of everything I did while I was in there... as for springs, thats up to you but I will still send you the link of what I went with. P.S. the bust boot and rubber mount that you will need on the new setup has to be taken off the old setup and reused.... I couldnt find a place that would just sell me those so i just reused them off the old setup.
Shorter dogbones (there a must):
http://www.zzperformance.com/grand_p...=890&catid=138
Anti Pogo washers (also a must):
http://www.zzperformance.com/grand_p...=403&catid=138
Springs (what I used):
http://www.zzperformance.com/grand_p...=454&catid=138
Struts
http://www.zzperformance.com/grand_p...=524&catid=138
Strut plates:
http://www.zzperformance.com/grand_p...=398&catid=138
And I also changed bot f+r sways bars if wanna do that while your in there here is the link for that:
http://www.zzperformance.com/grand_p...=571&catid=138
Here is a wheel bearing link:
http://www.zzperformance.com/grand_p...=837&catid=138
Hope his helps and you can get eveything you need, as for the springs, personally I would go with Moog, but thats up to you. lemme know what you ened up doing and I can help with instalation if ya need it!
Struts
Strut plates:
Slotted rotors and dual flowmasterr 44 will be next along with new rims and tires.
