Lowering Kit
Old Jan 28, 2011 | 09:49 AM
Crusader SS's Avatar
Question Lowering Kit
Good morning all... It is now time to replace my stock suspension at 190,000km (130,000miles)... It has performed admirably, but the rear end is starting to go soft... I am now presented with the option of installing a lowering kit (will be replacing all 4 struts & springs)... To lower her is an additional $300-$400 ($700.00 approx. for stock), I do not have the facilities or knowledge to DIY... I have looked around this thread and didn't find the info I was looking for (hopefully I'm not blind)... My question is, should I lower the car (by how much?)... What are the cons of this action?... Any suggestions would be extremely helpful... Thanks,
Old Jan 28, 2011 | 11:02 AM
SpinEm_90's Avatar
Here is the thread I made about lowering my monte...got lots of info in it! ZZP sells a combo pack thing that has their SSC Springs (which lower 1 in rear & 1.1 back), KYB GR2 struts, and anti-pogo washers all in one set for about 800. I can't find it atm but once I get on my laptop later I will post the link up here unless mod Mike still has it somewhere bcuz I believe it was in one of his posts that I got the link from a while ago. I wanted to get the springs that lower 1.4 front & 1 rear but I drive my monte everyday & that would probably be pushing it. Is yours a DD?
Old Jan 28, 2011 | 11:33 AM
Thanks for the info Britany, it is much appreciated... I'll check out zzp and the thread... Mine is a DD, too much pleasure lost to parkit... lol...
Old Jan 28, 2011 | 12:35 PM
Jomao_o's Avatar
If you get snowfall and drive it daily I wouldn't. You have the high sport, which has the extensions also, lower it even more and get ready to scream when you hear the extensions rub against the road/ice/snow.
... to me, that's a nightmare. Mine stock, already scratches at times, with the snow built up on our parking lot.
But its' up to you.
Old Jan 28, 2011 | 12:39 PM
But its' up to you.
Good point... We do get a fair amount of snow up here... If I do not go the Lowering root, what would you suggest as a beefed up stock set-up?... I really do want to have a good firm ride that would restrict roll & bounce... Thanks,
Old Jan 28, 2011 | 01:22 PM
7801MonteMan's Avatar
If you lower save your self some money. Do not buy the GR2...you will without a doubt love the AGX's so much better. I have riden on the both struts in Wbodies that are lowered and the AGX's were so much better in my opinion. You could lower only an inch using SSC or Vogtlands. Also a company called Cunuck autosports or something like that makes a lowering spring that is similar to the SSC's and lower the same as well.
Old Jan 28, 2011 | 01:44 PM
Thanks, I'll look into them... Really appreciated,
marz32
Aug 7, 2015 08:48 PM
BenitoL2012
Aug 23, 2013 12:24 PM
milrlyt
Sep 23, 2012 03:09 AM
Frosty LS1
Aug 24, 2009 02:14 PM
alabamamonte
Jan 19, 2009 11:00 PM
