Opinion Needed: Help please
Old Jul 11, 2022 | 09:27 AM
jamiebeahan81@gmail.com's Avatar
Default Help please
Hit a curb on front passenger side now wheel grinds and doesn't want to spin.what should I look for
Old Jul 11, 2022 | 02:04 PM
Sounds like you hit it pretty hard if that has caused that problem. It can be any list of damage depending how hard:
- Control arm
- Ball joint
- Tie rod
- Strut
- Wheel hub
Best to jack the car up and inspect for bent parts and obstructions.
Old Jul 11, 2022 | 08:12 PM
I'll add one more - the wheel itself. There isnt much clearance between caliper and wheel spoke on some wheel setups, so it wouldn't take a whole lot of bend to create contact.
Edit - adding another, the CV axle. Much less likely than some of the others mentioned (as the impact load should've been carried by the suspension as the CV can slip in and out), but crazier things have happened.
Justin Noga
Oct 31, 2020 02:55 PM
Shelbo Mustang
Feb 8, 2014 12:00 PM
Franks 03SS
Jun 1, 2012 08:10 AM
Franks 03SS
Feb 22, 2012 09:20 PM
