F Body Brake Upgrade
Im getting ready to upgrade my brakes on my car to the F Body Calipers & i was wondering what all ill need to do this, im buying all new parts, so if anyone can let me know wat all i need to order id appreciate it
if you buy them from ZZP the brackets are already tapped...so it should bolt right up...i recommend SS lines/ceramic pads though.
side note: make sure you mount them correctly the FIRST time...lol, also check the brake line for tension while turning, you can bend the bracket out a bit if needed....tension on brake lines = potential disaster..
Stainless brake line kit for your Wbody replaces all of your factory rubber lines. Provides a more responsive and firm brake pedal by eliminating the spongy feel that often accompanies stock rubber brake lines.
- PTFE inner hose covered by braided stainless steel
- Plastic coating keeps them looking nice and makes cleaning easy
- Includes 8 copper crush washers
- DOT approved
check this page out, it may help answer some questions
fbody brake upgrade - Brakes/Suspension/Chassis
7th Gen ('06-'07): sound upgrade/leather seat upgrade
lucasmblanco
Jan 27, 2014 12:20 AM
stlunatics2oo3
Sep 19, 2013 04:32 PM
SSmokybear
Nov 8, 2008 10:36 PM
