edelbrock suspension for a 79
Old Nov 1, 2010 | 07:36 AM
cheebah's Avatar
Default edelbrock suspension for a 79
hey all. I recently got a 79 monte. I posted a hello in the noob area some time ago. Anyway I was looking for a new suspension (front and rear) for my monte and found that edelbrock makes a full kit. I didn't see anything on the forum about the kit so I thought I should start a thread about it. Has anyone installed the kit for g-bodies? There are three varieties and I'm thinking about getting the pro touring kit. I wanted to know if edelbrock makes good suspension parts and if this kit was worth the $1500.
Also where the hell do y'all get carb rebuild kits? Im running the rochester dualjet 210 and i have only found one resource for a kit at http://www.carburetorfactory.com/kits_chevy.php
finally i wanted to add a little note about a guy i found who sells rear frame rails. I thought it was worth noting because it seems these rails rot out pretty quick and it can be costly to have new ones fabricated. http://www3.sympatico.ca/conradlozier/
Old Jun 10, 2012 | 10:11 AM
coffeebean's Avatar
I had to order a Tomco Rochester DualJet 210 from O' Reilly Auto Parts. They have two different versions of the same carb. I just purchased the one without the two electrical connectors that is on the front and on top on the left as you are looking at the carb. Mine was leaking and one of the tubes that went into the carb broke from the previous owner. I am now installing it and removing a bunch of vacuum tubes and such that is no longer required now days in my area.
Skeletal Crow
Dec 22, 2011 08:05 PM
Skeletal Crow
Apr 13, 2011 02:16 PM
wottreng33
Feb 7, 2010 10:21 AM
countryboy07
Dec 29, 2007 11:29 PM
